Ok we are talking in 3 different threads now about soft brake pedals.
What makes them soft?
What can be done?
We are not talking about brakes that don't work. It's just that doughy feel you get at the start of the brake pedal travel. I actually thought mine were completely stuffed when I upgraded my master cylinder but it seems that lots of Skylines have mushy pedals at the start of travel then get hard further down.
How about you? How does your pedal feel? How far does it go before you get the hard part if you have the mushy part as well? What rotors/pads/master cylinder? How recently was the system bled? I want to get an idea of what is normal.
https://www.sau.com.au/forums/topic/137090-the-new-soft-brake-pedal-thread/
don't know whether old brake lines would make a difference, given that they're rubber..
I have heard from people who have done it that a master cylinder stopper makes an enormous difference to brake pedal feel. not sure if that's at the start of the travel or just for hard braking though, the car was being tracked.
well you can get a firm pedal on a GTR, mine is brilliant.
Setup is as follows:
n1 brembo calipers front
standard calipers rear
hawk black pads all round
new rubber brake lines
standard master cylinder
regularly bled fluid.
Some things I would suggest:
* New brake lines.....15yo rubber is terrible. I had to put new rubber lines on for targa and they are excellent. I guess braided might be better but why pay extra?
* Regular fluid bleed
* Master Cylinder stopper (I cant do this but would love to, firewall flexes up to 2cm)
* some pads like bendix ultimate have a paper backing to the pad - you can remove this for extra feel.
If all fails try a new master cylinder or at least new seals. Also rebuild the pistons in the caliper.
my brakes don't feel soft at all...
my setup, which i had done about a month ago, is:
- stock rotors and calipers
- bendix ultiamtes
- motul fluid
- master cylinder brace ($65 from ebay!)
i can highly recommend a master cylinder brace / brace cylinder stopper :P
link for my BCS: http://cgi.ebay.com.au/Nissan-Skyline-BNR3...1QQcmdZViewItem
R33 ones are only $50 from that seller: http://cgi.ebay.com.au/Nissan-Skyline-R33-...1QQcmdZViewItem
BRace only helps with softness when you press the pedal down. The intial softness is not related to the brace, because the firewall hasn't flexed yet.
Also forgot to add, that I have changed the rubber lines. It didn't do anything which means that the old lines were fine.
That's interesting about the rotor and pad thickness. My pads are brand new, but the rotors are still the stock ones.
How thick are they meant to be new?
Edited by MANWHORE
ok,
well i have an r32 gtr, and my brake pedal for normal driving is fine, very nice and firm, but when i take it on the track and over say 140kph, there is a spongy point
when i start breaking and then it goes hard. So do you think that would be the firewall flexing or brake lines??
Brake lines then I guess. As the heat gets into the system from the heavier braking the lines axpand and flex a little.
I think with brakes you almost automatically bleed them if you have problems because that eliminates the cheapest issue.
What can be done?
i have a series 2 R33 and the brakes are awesome.... No mushiness at all...... the only thing that i have noticed is that if the brakes are really cold the first time you use them (like on hwy or similar) they don't grab quite as well..... However they work just fine after that initiial touch.... Great brakes actually, they pulled me up in a hurry to avoid a wallaby :laugh:
Does anyone sell the Master brace in Sydney ?
R32 master brace $65: http://cgi.ebay.com.au/Nissan-Skyline-BNR3...1QQcmdZViewItem
R33 master brace $50: http://cgi.ebay.com.au/Nissan-Skyline-R33-...1QQcmdZViewItem
delivered to your door in a week...
for less than half the price i don't see the problem....
apparently they have a warehouse with stock in melbourne
if they are out of stock it comes from hong kong
Warren.
What pads?
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
