so, I can kind of accept that a mistake could be made and they could be bolted on the wrong side.
However it is impossible that they would not notice that when they went to bleed them. Something dodgy there.
  • 3 months later...
Never ceases to amaze me, how just plain lazy people have become.
And have no pride in what they do.
Or that they can hold their head up high and call em selves a trade professional.
As Darren said.
SHAME SHAME SHAME.
  • 4 weeks later...
Good aye, I took my 95 N15sss to a brake place in Lismore the other day and was quoted $500 to rebuild the master cylinder, I saw a replacement part online for a much cheaper price, trouble is it's out of a 99 model and I'm not sure if they are interchangeable...any input would be very much appreciated...Andrew
  • 2 years later...
Recently just fitted a brand new 365mm D2 Brake kit, with WinmaxW5 race pads in the front and A1RM's in the rear, and topped up and bled with Castrol React SRF.
I haven't run the car on the track yet, but just moving the car onto the trailer I found the pedal to be soft and mushy. Is this to be expected with new pads and rotors?
  • Like 1
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
