Nice day, good fun , plenty of track time, just wish i had my car there to join in:(
Still enjoyed myself watching everyone go round though,
the Corsair challange was worth the price of admission alone. :O
Pits to ourselves
Reckon JP needs some more camber
Paul in the Territory,about to get swamped by the boat.
  • Replies 86
Yup, it was a great day. I got to drive 4 cars throughout the day. breaking the 1.40's in the corsair challange was one of the highlights, the next was putting the 2 tone territory through its paces. I did 175km in the GTR, 10 laps in the territory and about 8 laps in the corsair, and I rounded the day out with 3 laps in Abo's weapon, until the fuel light came on.
All in all I think I spent more money on petrol then track hire, thats the way it should always be.
I will continue to chase OP for L2S days and keep the post up and current. As it gets hotter I would encourage everyone not to do too many track days.
Thanks to everyone who played in the corsair challange, the car lasted so I cant see why it wont keep running, with the entry fee's , john should be able to keep the car running.
Yup, great fun day. It's also so relaxing to go to a track day and only have to organise myself.
Tried out the new diff. Was up to 2:30am the night before putting it in at Majanals place in the mountains.
It definitely changes things. I came down the straight at about 200km/h, stabbed the brakes for turn 1 then a little gas to turn 2 but was too much because of the diff and lack of rear end grip (my semis have had it), so at about 160km/h I spun around and off into the kitty litter. Had to get towed out but no damage.
That's my first big lose ever on the track. Kind of fun although I would have preferred to do it at a slightly slower speed.
Also enjoyed taking the mighty MADGTR for a spin. The GT-SS's really are great on that engine. It almost feels like a non turbo it's so linear. You really feel the extra weight when braking but the grip is unbelievable.
WHAT A BLAST
I had a GREAT day....
Very different to a normal track day.........sooo much track time, and no pressure.
Must get an in car timer,(thanks Paul for the lend) it really does improve your times when you have instant feedback on each lap.
Being first up in the Corsair Challenge Car, i obviously babied it too much, turning in a 1.46, but hey, the clutch really was crap, and i didn't wish to be the one to spoil everyones fun. I'd have been drummed outta here if it crapped itself. I gave it another go later, on a semi oiled track, redeemed a little dignity with a 1.43
Much was learnt this day (must take jerry cans fulla fuel)
A Special Thanks to my fellow enthusiasts who helped create a perfecty day!
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
