Hi everyone!
Can someone please point me in the direction of an extrude honing service in Adelaide?
They are quite elusive, white and yellowpages search didn't come up with the goods.
The only company that I can find on the net is Abrasive Flow Engineering in Sydney.
I hope someone can help.
:D
https://www.sau.com.au/forums/topic/137096-extrude-honing-in-sa/
In case anyone is interested, I was just quoted $650 from Abrasive Flow Engineering to extrude hone my standard RB25 exhaust manifold.
They told me they have done them before, and have increased their flow capability from ~130cfm to ~170cfm.
Not a cheap exercise! Nuts :no:
In regards to my setup, since it is the only part of the exhaust tract that has not been modified (ie. enlarged), I'd expect some power gains, how much remains to be seen.
Say you have a setup with a standard exhaust manifold that is pushing the turbo to its limit at the top end, with boost falling off near redline, would this mean that most of the gains from extrude honing be made in the midrange?
What do you guys think?
Cubes, like anything, they are good up to a point. They are certianly good for response. Either way by getting an aftermarket one you are only gaining say, 5% power at the very best so value for money aint there and you have to deal with the tradeoffs (heat/not stock looking/worse response for equal lengths etc).
Turbo Tits, if boost is falling away its more likely the compressor is running out of puff. The manifolds increase the engine's volumetric efficiency, rather than the turbo's capabilities. There might be some gains to be had on the midrange but who knows... Remember you can have the primaries as large as you like but the exhaust pulse still has to squeze thru the relatively squashed turbine housing. Sorta like a storm drain with a garden spray jet on the end.
Just a quick update.
I got in touch with Andrew from Specialised Power Porting in Victoria. He's asking $550 for his extrude honing service. Sounds like a great guy, really helpful and willing to chat.
General turnaround time is 2 weeks. But he said if you call a few days in advance and let him know when the manifold will arrive, he can pencil in into his workload and can have it done in a few days.
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
    • Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
