hey guys.
Saw these on ns.com
http://www.nissansilvia.com/forums/SAGA-GA...in-t190346.html
look pretty good, they have fully adjustable warning levels and peak recall, anyone used or has these?? as Im looking to get some.
cheers
Edited by sky120
》High precision/full angle step motor used by the core.
》Full series electronic high-precision sensor (error±1%)
》Max. panel (58mm)/Super thin cylinder (44mm) design
》Abnormality self-detection warning function.
》ON/OFF self-sweeping inspection function
ON/SLOW, FAST Arm secondary sweep
OFF/ FAST, SLOW Arm secondary sweep
》Nighttime light source brightness automatic attenuation
》Alert value setting, Arm Flickering/Buzzer Sounding function
》Black/Heat Resistant/Anti-UV optical Mask design
》Self-illumination/High Contrast/Optical Panel Lighting design
》Use high-illumination/longer life LED Light Source
》Light weight, high heat-dissipation, full aluminum alloy precious metal shell.
》Aluminum alloy seat and dashboard sunscreen.
》External connection large size warning Indicator (optional)
》External control box not required.
》Peak value record Play/Check function.
》Available for connecting water-temp. control fan ON/OFF function (optional)-
》Delayed shutoff (Auto Timer) Expansion function (optional)
Sounds like a copy and paste off the product description form a generic chinese manufacturer.
although saga look good, the new Stri DSD range at advan in sydney look abit better, the reason I say is that the have ones which arent that crappy smoked look. which can be annoying in the daytime.
they have much the same features, memory and recall and all that, and the guy at advan said they would range from about $85 to $150, Id be interested in the accuracy
theres going to be reviews in a major car mag soon im told
the only function that they lack, as far as I can tell is the option for an external warning feature like a buzzer.
has anyone tried these?
http://www.stri-racing.com/home/
Edited by midnight
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
