hey guys.
Saw these on ns.com
http://www.nissansilvia.com/forums/SAGA-GA...in-t190346.html
look pretty good, they have fully adjustable warning levels and peak recall, anyone used or has these?? as Im looking to get some.
cheers
Edited by sky120
》High precision/full angle step motor used by the core.
》Full series electronic high-precision sensor (error±1%)
》Max. panel (58mm)/Super thin cylinder (44mm) design
》Abnormality self-detection warning function.
》ON/OFF self-sweeping inspection function
ON/SLOW, FAST Arm secondary sweep
OFF/ FAST, SLOW Arm secondary sweep
》Nighttime light source brightness automatic attenuation
》Alert value setting, Arm Flickering/Buzzer Sounding function
》Black/Heat Resistant/Anti-UV optical Mask design
》Self-illumination/High Contrast/Optical Panel Lighting design
》Use high-illumination/longer life LED Light Source
》Light weight, high heat-dissipation, full aluminum alloy precious metal shell.
》Aluminum alloy seat and dashboard sunscreen.
》External connection large size warning Indicator (optional)
》External control box not required.
》Peak value record Play/Check function.
》Available for connecting water-temp. control fan ON/OFF function (optional)-
》Delayed shutoff (Auto Timer) Expansion function (optional)
Sounds like a copy and paste off the product description form a generic chinese manufacturer.
although saga look good, the new Stri DSD range at advan in sydney look abit better, the reason I say is that the have ones which arent that crappy smoked look. which can be annoying in the daytime.
they have much the same features, memory and recall and all that, and the guy at advan said they would range from about $85 to $150, Id be interested in the accuracy
theres going to be reviews in a major car mag soon im told
the only function that they lack, as far as I can tell is the option for an external warning feature like a buzzer.
has anyone tried these?
http://www.stri-racing.com/home/
Edited by midnight
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
