whats the reason behind this????
Sold me a car that could not be driven, and had LOTS of illegal parts on it
After they had my money they would not even talk to me
They did not change the tires on the car to aus. legal tires
Alam was not wired correctly, and drained the battery
Spacers on the wheels - wheels rubbed into the wheel guard
POD filter not secured and not covered
etc
etc
etc
https://www.sau.com.au/forums/topic/137129--/#findComment-2549587
We went there once and MOST of their cars are in really crap condition....You have to be careful with places like that....they'll rip ya off.... :( Especially around the Northern Suburbs area....Did you go down there to purchase the car??
https://www.sau.com.au/forums/topic/137129--/#findComment-2549611
Yep, JSA is well known for that sort of stuff.
It's kind of a big joke really
Sorry to hear about what happened.
Why can't it be driven?
Yeh flew down to Melb to buy the car. They took everything off the car, got it complied and then put it back on - i didnt know at the time half of it was not legal... by the time i found out it had been a fair while.
It can be driven now, but i had to spend a LOT to get it drivable and legal
Tires scrubbed out when driving over a little bump or cats eye due to spacers
I have been having an ongoing battle with them and they threatened to "countersue" if I proceeded with legal action.
https://www.sau.com.au/forums/topic/137129--/#findComment-2549619
etc
etc
etc
why the hell did you buy it then if so much was wrong with it?
https://www.sau.com.au/forums/topic/137129--/#findComment-2549620
ahh I see.. yer thats pretty dodgy.
The car was stock when i test drove it (they said for compliance they had to have it stock)
Then they said i would get all these nice extra bits (most of which were illegal)
They complied it, then wacked all the other stuff on, trucked it up to me and then wouldnt talk to me
https://www.sau.com.au/forums/topic/137129--/#findComment-2549654
R33 GTS-t
Problems were:
Alarm incorrectly wired
Spacers
No hub locators (dangerous)
Cat back exhaust (not turbo back as promised they would put on)
No coil over suspension as promised
Tires not Aus. legal
AND they void the warranty they supplied before i got the car (it is only valid if car is STOCK - what a scam)
https://www.sau.com.au/forums/topic/137129--/#findComment-2549680
tell them your gonna take am to consumer affairs and see how quickly they change there tune then :(
I've done that
They threatened to counter sue, and consumer affairs said i have to take it up to the next level because it has been 12 months now, im still finding things to fix, only JUST found the battery drain problem last month (it was the alarm which they installed)
Has anyone sued a car yard in a similar situation before?
I am 90% decided I will go down this road very shortly
https://www.sau.com.au/forums/topic/137129--/#findComment-2549701
lol. i fail to see what case they would have if they counter sue... judginy by what you said they've participated in illegal business practices
unless you signed some form of contract i dunno what they can counter sue you with
Well I dont think its legal to strip a car down, comply it, and they put the parts back on to sell it.
Im sure if they tried to comply it with the jap tires etc then it would not have passed, so how can they expect me to drive it like that if it would not comply.
The "counter sue" was just a bluff I expect, what can they sue ME for? being dumb enough to buy a car from them is all I can think of
https://www.sau.com.au/forums/topic/137129--/#findComment-2549734
are the a RAWS workshop??? if so, they DEFINITELY need to be reported. SEVS was partly introduced to get rid of this shit
exactly. and the fact it still has japanese tyres on it... screams sus lol
umm yeah that was my point with that post...
lol
https://www.sau.com.au/forums/topic/137129--/#findComment-2549746
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
