whats the reason behind this????
Sold me a car that could not be driven, and had LOTS of illegal parts on it
After they had my money they would not even talk to me
They did not change the tires on the car to aus. legal tires
Alam was not wired correctly, and drained the battery
Spacers on the wheels - wheels rubbed into the wheel guard
POD filter not secured and not covered
etc
etc
etc
https://www.sau.com.au/forums/topic/137129--/#findComment-2549587
We went there once and MOST of their cars are in really crap condition....You have to be careful with places like that....they'll rip ya off.... :( Especially around the Northern Suburbs area....Did you go down there to purchase the car??
https://www.sau.com.au/forums/topic/137129--/#findComment-2549611
Yep, JSA is well known for that sort of stuff.
It's kind of a big joke really
Sorry to hear about what happened.
Why can't it be driven?
Yeh flew down to Melb to buy the car. They took everything off the car, got it complied and then put it back on - i didnt know at the time half of it was not legal... by the time i found out it had been a fair while.
It can be driven now, but i had to spend a LOT to get it drivable and legal
Tires scrubbed out when driving over a little bump or cats eye due to spacers
I have been having an ongoing battle with them and they threatened to "countersue" if I proceeded with legal action.
https://www.sau.com.au/forums/topic/137129--/#findComment-2549619
etc
etc
etc
why the hell did you buy it then if so much was wrong with it?
https://www.sau.com.au/forums/topic/137129--/#findComment-2549620
ahh I see.. yer thats pretty dodgy.
The car was stock when i test drove it (they said for compliance they had to have it stock)
Then they said i would get all these nice extra bits (most of which were illegal)
They complied it, then wacked all the other stuff on, trucked it up to me and then wouldnt talk to me
https://www.sau.com.au/forums/topic/137129--/#findComment-2549654
R33 GTS-t
Problems were:
Alarm incorrectly wired
Spacers
No hub locators (dangerous)
Cat back exhaust (not turbo back as promised they would put on)
No coil over suspension as promised
Tires not Aus. legal
AND they void the warranty they supplied before i got the car (it is only valid if car is STOCK - what a scam)
https://www.sau.com.au/forums/topic/137129--/#findComment-2549680
tell them your gonna take am to consumer affairs and see how quickly they change there tune then :(
I've done that
They threatened to counter sue, and consumer affairs said i have to take it up to the next level because it has been 12 months now, im still finding things to fix, only JUST found the battery drain problem last month (it was the alarm which they installed)
Has anyone sued a car yard in a similar situation before?
I am 90% decided I will go down this road very shortly
https://www.sau.com.au/forums/topic/137129--/#findComment-2549701
lol. i fail to see what case they would have if they counter sue... judginy by what you said they've participated in illegal business practices
unless you signed some form of contract i dunno what they can counter sue you with
Well I dont think its legal to strip a car down, comply it, and they put the parts back on to sell it.
Im sure if they tried to comply it with the jap tires etc then it would not have passed, so how can they expect me to drive it like that if it would not comply.
The "counter sue" was just a bluff I expect, what can they sue ME for? being dumb enough to buy a car from them is all I can think of
https://www.sau.com.au/forums/topic/137129--/#findComment-2549734
are the a RAWS workshop??? if so, they DEFINITELY need to be reported. SEVS was partly introduced to get rid of this shit
exactly. and the fact it still has japanese tyres on it... screams sus lol
umm yeah that was my point with that post...
lol
https://www.sau.com.au/forums/topic/137129--/#findComment-2549746
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
