They are 100% The R32 RB25DE injectors that came with bl4ck32 and my own head were both red top high imp injectors. I dropped a multimeter on them myself.. 100% high imp. Same part numbers everything.
The R32 RB25de's don't run a resistor pack of any kind, its not in the diagrams in the engine manual, only the rb26 does.
I'm sure mr_rbman could also confirm as he too ran a R32 RB25de head on his rb30.
Interestingly the injectors that came out of my rb20det were clear top with a red dot. Not that it has anything to do with r32 rb25de but I found it interesting. They must have run out of red plastic. ;)
;) he is correctomundo :ninja:
  • Replies 160
Posted Images
So you've got your self a set of R33 GTST 370cc Injectors?
How do you plan to fit them as they are sidefeed?
If your running a pfc you will obviously have to trim the injectors and also adjust the lag values for it to run correctly.
From memory the R32 RB20DET/RB25DE injectors run a 0.77ms lag time where as the R33 injectors are around the 0.54ms lag time.
gl with it! Dropped my 32 in today to get rb25'd (gearbox + engine) seems like a natural occurance these days :blink:
You going to be at DECA?
Also, where are all you ppl getting the R32 RB25DE heads/engines from? Ppl are asking RB25DET money for them :(
LOL...im going to be the last 20 running around :)
I am thinking of doing the same conversion but will hold out for some of the results.
I wonder how much boost you can safely run with 10:1 CR and how much timing you will have to pull out.
230rwkw and some torque is what I am after. I have everything already on the 20 and the turbo on the way. I am just missing some displacement :(
LOL...im going to be the last 20 running around :no:
I was lucky and picked mine up through a mate who has a mate that runs a import place, lol. I dont think they know about the engine being able to mate up with the RB30 either and im gonna keep my mouth shut. Picked up my motor with all accesories flywheel and clutch for $495, not bad hey.
Also, where are all you ppl getting the R32 RB25DE heads/engines from? Ppl are asking RB25DET money for them :D
LOL...im going to be the last 20 running around :D
Hey Roy,
Car is in at driftline, ive been eta'd 1-1.5weeks so hopefully i should be able to make it to deca. Car will be forced to run without a proper tune though so i really dont know how much i want to push it
Yes we did discover that.. lol i forgot that was written in this thread!
I am pretty sure Nathan worked out which ones run at the correct impediance to run this DE+T engine.
anyone want to see more of her in the gearbox tunnel LOL!!1
:sick:
Don't you dare bitch!! :yucky:
Edited by RB_turbo_bitch
Hi there, ive actually just put a RB25DE, +T into my R32 and removed all the hicas and fitted a lock bar. You said you put a spacer on the rack, just wondering what it was for?
here's some pics of the spacer..
" wonder how much boost you can safely run with 10:1 CR and how much timing you will have to pull out."
I was running 7psi in the R34 no problems, and it was making some good power. A final tune would have seen it with 9psi...but it was stolen before then. If I'd put bigger cams in I think 12psi could have been a real possibility with blinding performance.
Nice.. well the head's coming off it today so we'll see what happens!
Righty,that's why the confusion.Looks like you meant it was in the steering column,not the rack.Have you driven a car with one fitted? Any drawbacks to them?
No no i am putting spacers in the steering rack as well as the steering column (pics above)... they are called MAGIC WASHERS buddy!
A non-hicas S13 sreering rack and rear cradle are also being fitted.
and no i haven't driven a car with one fitted before...
whats the benifits of putting a s13 rack in?
cheers
Jeremy
Grab the s13 power steering filler bottle thing too as it only has one hose outlet on it, i just clamped a bolt onto the unused outlet for now until i get one.
Ive mucked around a fair bit with the wolf to get my idle, cold/hot start sorted out and the car is behaving perfect now, so its just 8 days away from dyno tuning.
I did drive it to get the aircon regassed, gave it a few half throttle hits and it had 7-8psi by about 2600rpm, on the freeway where i had space to play it was seeing 15psi just over 3000rpm but under load it just started to ping so i took it easy from then on.
As my wastegate has a 1 bar spring thats the boost ill be using, as long as i can control myself not to wind it up with the ebc.
cheers
Jeremy
It's quicker then any r32 rack (less turns from lock to lock! ...and then i have nice light steering and a fully locked rear end!!
Yep I am using one of them!!
Nice.. let me know how the tune went and the power output!
boss is doing a rb25de (32) + T into works drift ceffy
1.8mm h/g to4 style turbo and external gate
should be good 25 det g/boc
and some 700cc inj out of his drag 32 gtr
going microcrack
anyone got advice on the cams?
I think he's after 250-300rwkw
