They are 100% The R32 RB25DE injectors that came with bl4ck32 and my own head were both red top high imp injectors. I dropped a multimeter on them myself.. 100% high imp. Same part numbers everything.
The R32 RB25de's don't run a resistor pack of any kind, its not in the diagrams in the engine manual, only the rb26 does.
I'm sure mr_rbman could also confirm as he too ran a R32 RB25de head on his rb30.
Interestingly the injectors that came out of my rb20det were clear top with a red dot. Not that it has anything to do with r32 rb25de but I found it interesting. They must have run out of red plastic. ;)
;) he is correctomundo :ninja:
  • Replies 160
Posted Images
So you've got your self a set of R33 GTST 370cc Injectors?
How do you plan to fit them as they are sidefeed?
If your running a pfc you will obviously have to trim the injectors and also adjust the lag values for it to run correctly.
From memory the R32 RB20DET/RB25DE injectors run a 0.77ms lag time where as the R33 injectors are around the 0.54ms lag time.
gl with it! Dropped my 32 in today to get rb25'd (gearbox + engine) seems like a natural occurance these days :blink:
You going to be at DECA?
Also, where are all you ppl getting the R32 RB25DE heads/engines from? Ppl are asking RB25DET money for them :(
LOL...im going to be the last 20 running around :)
I am thinking of doing the same conversion but will hold out for some of the results.
I wonder how much boost you can safely run with 10:1 CR and how much timing you will have to pull out.
230rwkw and some torque is what I am after. I have everything already on the 20 and the turbo on the way. I am just missing some displacement :(
LOL...im going to be the last 20 running around :no:
I was lucky and picked mine up through a mate who has a mate that runs a import place, lol. I dont think they know about the engine being able to mate up with the RB30 either and im gonna keep my mouth shut. Picked up my motor with all accesories flywheel and clutch for $495, not bad hey.
Also, where are all you ppl getting the R32 RB25DE heads/engines from? Ppl are asking RB25DET money for them :D
LOL...im going to be the last 20 running around :D
Hey Roy,
Car is in at driftline, ive been eta'd 1-1.5weeks so hopefully i should be able to make it to deca. Car will be forced to run without a proper tune though so i really dont know how much i want to push it
Yes we did discover that.. lol i forgot that was written in this thread!
I am pretty sure Nathan worked out which ones run at the correct impediance to run this DE+T engine.
anyone want to see more of her in the gearbox tunnel LOL!!1
:sick:
Don't you dare bitch!! :yucky:
Edited by RB_turbo_bitch
Hi there, ive actually just put a RB25DE, +T into my R32 and removed all the hicas and fitted a lock bar. You said you put a spacer on the rack, just wondering what it was for?
here's some pics of the spacer..
" wonder how much boost you can safely run with 10:1 CR and how much timing you will have to pull out."
I was running 7psi in the R34 no problems, and it was making some good power. A final tune would have seen it with 9psi...but it was stolen before then. If I'd put bigger cams in I think 12psi could have been a real possibility with blinding performance.
Nice.. well the head's coming off it today so we'll see what happens!
Righty,that's why the confusion.Looks like you meant it was in the steering column,not the rack.Have you driven a car with one fitted? Any drawbacks to them?
No no i am putting spacers in the steering rack as well as the steering column (pics above)... they are called MAGIC WASHERS buddy!
A non-hicas S13 sreering rack and rear cradle are also being fitted.
and no i haven't driven a car with one fitted before...
whats the benifits of putting a s13 rack in?
cheers
Jeremy
Grab the s13 power steering filler bottle thing too as it only has one hose outlet on it, i just clamped a bolt onto the unused outlet for now until i get one.
Ive mucked around a fair bit with the wolf to get my idle, cold/hot start sorted out and the car is behaving perfect now, so its just 8 days away from dyno tuning.
I did drive it to get the aircon regassed, gave it a few half throttle hits and it had 7-8psi by about 2600rpm, on the freeway where i had space to play it was seeing 15psi just over 3000rpm but under load it just started to ping so i took it easy from then on.
As my wastegate has a 1 bar spring thats the boost ill be using, as long as i can control myself not to wind it up with the ebc.
cheers
Jeremy
It's quicker then any r32 rack (less turns from lock to lock! ...and then i have nice light steering and a fully locked rear end!!
Yep I am using one of them!!
Nice.. let me know how the tune went and the power output!
boss is doing a rb25de (32) + T into works drift ceffy
1.8mm h/g to4 style turbo and external gate
should be good 25 det g/boc
and some 700cc inj out of his drag 32 gtr
going microcrack
anyone got advice on the cams?
I think he's after 250-300rwkw
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
