Crash happened on the corner of William st and New south head rd in double bay, no one hurt or injured (i think). Happened around 3pm Today 3/10/06
Anybody know him? GTR btw
He went into the Wollahra Kindergarten, don't think any other cars were involved.
Edited by Savman
https://www.sau.com.au/forums/topic/137131-skyline-crash-double-bay/
  • Replies 220
Posted Images
Holy %$#@
hope no-one was hurt hey, looks like a nasty accident.
LOOKS LIKE THIS ONE --------> http://www.skylinesaustralia.com/forums/in...howtopic=132231
PICS ---------> http://www.antilag.com/personal/morgs/gtr/
Edited by MrVspec
Can you notice that it has massive dish in the front.. The pictures dont show any dish at the front.. Hope i'm right.
Its on an angle - and not showing dish the same way my one doesnt show front dish when turned
So, who's going to ring Morgs and see if its him?
Edit: Alex, if you checked the link, you wouldve found this:
Its looking more and more like Morgs
Morgs sold the car right?
Well if you go to www.autostyle.com.au its still advertised, but maybe they havnt updated their site in a few days and it was sold today? Who knows
NISSAN SKYLINE COUPE
Stock # R32GRN
please click on an image to enlarge and view slideshow
Registration Variant
GTR
Transmission Odometer
MANUAL 105000
Series Engine
R32 2.6LTR
Colour Year
racing green 1989
Features
Air Conditioning Adjustable Steering Wheel
Alloy Wheels Compact disc player
Central Locking Remote Control Engine Immobiliser
Leather Steering Wheel Power Mirrors
Power Steering Power Windows
Rear Spoiler Sport Seats
Detailed Information
Fantastic value for a 400KW GTR at under $35,000. Only 3500klm on built engine. (all reciepts, full rebuild) ARIAS forged pistons, EAGLE forged H-beam rods, TOMEI metal head gasket, TOMEI sump baffle, N1 water & oil pump, APEXi 270 deg cams, Adjustable cam gears, APEXi fuel reg, 720cc injectors, BOSCH 044 fuel pump, Z32 AFMs with Greddy 80mm intake & APEXi pod filters, TRUST Type R BOV, remote oil filter, VSPL front mount, Iritop 8 plugs, HKS exhaust manifold, HKS GT 60mm external waste-gate with screamer, Garrett TO4Z turbo, Full Vspec N1 body-kit - Skirts, rear lip, front vents, bonnet lip, Impul 17x9.5" rims 3 piece, lightweight, wrapped in RT215 Azeni 255/40/17s, BILSTIEN suspension. New castor rod bushes etc, short-shifter, DBA 4000 series rotors (new) front & rear with Fereodo pads, Front AND rear Strut Braces, APEXi PowerFC, APEXi Hand controller, BLITZ Dual SBC-R, CD Player, GREX Gearknob, Aftermarket Steering Wheel. , For more details give Domenic at AUTOSTYLE Prestige & Performance Cars a call on (02) 9580 1447.
Price:
$34,900
Yes, Morgs sold the car and is in Melbourne, so it wasn't him.
Good to hear
Rick sold the car to some business man, who then put the car back up for sale after a week because it smells like fuel .....
Anyhow, it was on carsales.com.au ... I'm not sure if someone else bought it before this.
Thats a tragedy, that was one of the nicest GTR's in the country.
P.S Dibs on driveline...... Seriously I hope all are ok.
Edited by teejay
man that looks so much like morgs car. even has the same tyres on it (RT215s). Fark me ragged I hope it wasn't him. The wheels are definately different though so it may not be his car, though there would not be too many Green R32 GTRs in sydney, especially on RT215s... let's hope it's another one.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
