yeah i dunno why no-ones interested, had a few offers on carsales and a few calls, but unfortunatley the timing was all wrong as i was on a holiday for a week in QLD (first holiday in 13 years!!!)- definitely nothin wrong with it, any tests are welcome on it... ah well, been drivin it a lil bit lately and its good fun! So no urgencies on the sale.
Edited by DRIFTPIG
https://www.sau.com.au/forums/topic/137147-sold/#findComment-2661652
bloody nice lookin car ya got, but unfortunately it would be out of my price range.. not lookin to puch much.. if anything on top of the skyline. Thanks anyway, GL with sale, cheap for what it is!
https://www.sau.com.au/forums/topic/137147-sold/#findComment-2675387
i reckon cause i wrote that the body is a lil rought that it has put off people. Its nothing bad, in fact its probably the same condition as 99% of r33's, but it is 11 years old, so its got some general wear and tear.
Also i have been to look at many cars before over the years, and theres nothing worse than when the "forget" to tell you something bad about the car. So im trying to be over honest so i dont waste anyones time... This way i believe the first to see/drive will buy it.
https://www.sau.com.au/forums/topic/137147-sold/#findComment-2676139
nah had some low offers already, but as others have stated, its pretty cheap for the modifications on it. If i got desperate i'd take the nearest offer and they're a fair bit closer to the mark than $13k sorry cheif.
https://www.sau.com.au/forums/topic/137147-sold/#findComment-2693536
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
