Hey,
I have this clicking sound coming from (sounds like it) from the dashboard it only happends for about 5-10 seconds once the car is turned on or on reds.
I've been told it is one of the relays, if so how would I go about fixing it?
R33MidnightRacer
https://www.sau.com.au/forums/topic/137174-clicking-sound-in-dashboard/
Hey,
R33MidnightRacer
mate there was a thread bout this 3 months ago, but anyway it's air con/fan speed related, the part in question is the blend door actuator, it's a dash out job, part cost me 90 odd bucks and did it myself when i pulled the dash out 4 painting or quoted 600 odd by auto elecy 4 the job cheers
Fark!! Looks like a nightmare with everthing off. Not as helpful as i would of liked. I know how to undo most parts, as i installed my system n shit. Where exactly is this 'blend door acutator', and what does it look like? Cheers..... :laugh:
Nightmare to say the least, what Mr33 said, where exactly would it be? When I took it to my local performance shop they said "ahh, don't worry its only a relay" ..Mmm this makes me confused.
A relay?
It should be a like a little white circle teeth grooved clock lookin thingy hahahh.
I think that round thing gets stuck as it turns..
I think security (member on here) with the yellow r33 did it a while back. Hopefully he replies in this thread.
Otherwise just leave it. Nothing will happen. But does get annoying after a while eh??
Yeah def annoying, but is it actually NOT doing something while it's 'broken'?? $90 seems bloody expensive, where can ya get this part?? Ya sure that's what its called, i don't wanna sound like a dick at the shops! lol :laugh:
i got the part second hand from the wreckers, the one down gold coast way, rolin imports i think
thats the tecknical name for it used by auto elecys, the wrecker really had no idea what i was talking bout so i went through thier shit and found it
Edited by teamplasma
New the part from nissan is about $150, i replaced mine with a new one, didn't want ti happening again. yes dash out job, its the black box about the size of a pack of cards on top of the heater box as seen in this photo:
http://gtr.ferni.net/misc/dash_removal/sli...ter_unit02.html
It's actually not that bad of a job, you don't need to take the heater box out, just the dash out of hte way, getting the heaterbox out was a bitch when i had to do my heatercore.....
Goodluck.
teamplasma, did you grab the whole black box or just the thing inside?
ferni, hey cheers for that! That's the pic i was after. Yeah like siddr20 said, do ya replace the whole box or what's inside? Thanks guys...... :D
yer the black box thats bout the size of a pack of cards, just replace the whole unit, it'e easier
it;s actually called the blend door actuator and it is a bit of a bugga of a job but i replaced mine when i was doing the heater core i paid 40 bucks for one of a member who was wrecking a r33
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
