Hey!
Just wanted peope's opinion on good places around Queensland to take some good photos of my car? Maybe old train tracks, tagged backgrounds etc etc.
If anyone could suggest any places please do post them here, and any pictures of the backdrop if you have taken photos there already would be awesome.
Thanks SAU QLD :ermm:
R33MidnightRacer
https://www.sau.com.au/forums/topic/137182-good-photo-backdrops/
just a few i can list for you
city backdrop -
mt cootha lookout
kangaroo point up the up of the cliff
at southbank in front of the qpac building where the grass area is
parked in the city (i taken one along creek street) with high rises in the background.
gateway bridge backdrop -
murrie
forrest backdrop -
park along the side of the road heading up the mountain of Mt Tamborine in a shaded area with some tree's yet a open view of the mountains
goldcoast backdrop -
along the road at the spit
along the esplande while driving
parked in the business area of southport (awesome jacaranda tree in that area)
along the indy track.
other backdrop -
parked in a underground carpark lit-up with numbers on each post.
with that last one. find a level with no cars on it and well lit up at night or day making sure there is no sun that is getting in. numbers on each post makes the image look more interesting.
take as many angle shots as you can while parked in the driving lane. park it either straight or on a angle
with the indy track one. this would be the best time of year. the walls are up and as the track is close to completion, most of the sponsor signs are up to. try and find someone to get in a 2nd car and take photo's of your car driving around on the indy track (make sure there are no other cars in the photo).
this would in turn make your car look like it was actually driven at the time of indy and you were racing on the track either well ahead of behind all the other racing cars. LOL
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
