Hey guys I ran my car last Friday at Calder backed of at say 5000rpm in first gear coz it bogged and held back.
Initially, I assumed I had a vaccum leak from were i plumbed my blow off valve from. Cant be fuel supply coz I had a full tank.
However, after removing the tube and returning the blow off valve set up back to atmospheric It bogged a little again. It only happens when Im hard on the throttle every now and then. Some times its cool and sometimes it decides to bogg.
It made 211.8 rwKW on 14psi at C&D with a dump back exhaust (no cat), SAFC, APEX fmic, fuel pump. Car showed no signs of problems on the dyno. It made 193 rwKW on 8psi. Will post dyno graph shortly.
Need to know before Friday coz im running it again at Calder. Any info will be most appreciated.
PS plugs are gapped at 0.6mm, motul turbolight and use BP ultimate.
Any ideas what i should expect from 1/4 mile time and mph. (Using standard suspension and street tyres.)
.6 is far too much, should be no more than .8
If you need to go to .6, you probably have a coil issue, or plugs arent good condition
As for times, 105mph @ 13.5 is my stab for around the 190-200rwkw mark, bein you do have a stock turbo...
And i wouldnt be using 14psi. Its really pointless IMO.
Go back to 10-11psi, will save the turbo from dying aswell.
I ran 12.9 @ 109 in 225s with 215-220rwkw :ermm:
My mate has 235rwkw 12.4sec 1/4mile and runs the same plugs with 0.6mm gapping and has never had a problem. btw the plugs in my car are brand new. Just to remind you... there were no signs of problems in ignition or fuel supply on the dyno.
Any ideas on my suspension set-up?
Thanks in advance.
So what if he didnt have a problem?
Are we talking about your mate and his or your car here dude? :D:ermm:
Things might well have been fine on the dyno, but they (obviously) arent now are they? :sorcerer:
Plugs being new doesnt mean a lot when the gap indicates you have ignition issues if they are gapped down that far, hell... i was running 24psi, 269rwkw and race fuel and i didnt need them gapped that small.
No-one is going to have a magical answer for you, it could be lots of things, ignition is the place to start however.
As for your suspension, you have what you have is not going to affect times greatly when you have what is essentially a stock car
It will come down to driver/launch/tyres more than suspension at this stage of the game... plus tyres are cheaper, and expirience is free.
So again, my prediction above of 13.5 @ 015mph stands... if you cant drive, closer to 13.8
Reducing your plug gap to 0.6mm is only hiding your miss. You have a problem with it so you need to fix it. Reduce your gap will fix it, but your performance will suffer slightly. Your call.
I had the same problem and had to reduce the gap to 0.65mm , then i bought some spitifires and now run them at 0.85mm gap with alot more boost, no misses what so ever.
In summary, 212 rwkw and an SAFC with the standard turbo.
Night time, colder (denser) air compared to daytime, hotter air on the dyno.
My first guess would be that the standard ECU is getting into R&R mapping because of the increased airflow.
My suggestion would be to ake it back to your tuner and tell him what is happening. He may be able to sneak a bit more corection into the SAFC to allow for the night time running
OR
Wait unilt summer before you run it at night time drags.
:P cheers :huh:
Yeah ran again the following friday.
14.2sec @ 100.9mph @ 8psi
13.8sec @ 104.9mph @ 10psi
13.9sec @ 105.5mph @ 12psi
13.7sec @ 104.8mph @ 11psi (this last run i plumbed my blow offf valve back whilst waiting in line)
My 60ft times were shocking they ranged from 2.3-2.6secs. My tyres let me down they were only 25/225's and hard compound. So in regards to my mph im guessing a low 13 with good traction.
I did hit R/R mode about three times but once I put my headlight back in place it ran fine.
One thing im worried about is that whilst burning up the tyres before my run i noticed that my rev limiter does not exist. My leg was still flat on the throttle and somehow i pushed the clutch in at the same time (dont ask why i was nervous!!!) so thereby placing it in neutral; my revs went all the way to 9000rpm.
Any idea to wether or not my engine has been rebuilt in japan? Or am i dreaming? Im guessing when the SAFC was installed by the previous owner in Japan they removed the limiter. But it must be for a reason!
Now, should I opt for a PFC first or a Turbo upgrade (thinking of something with response say GT2871R with 0.86 exhaust A/R) ?????
Thanks you to all in advance.
Bill
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
