something different...
that pizza and pasta place half way down norton st leichartt (sp?), cant remember name
That pretty much descirbes ALL of Norton St, John...
But there are definitely some better choices along there.
Maybe Crows Nest???
Has some awesome places like Pino's etc etc... been to a few tops Italian places there!! Plenty of parking too aruond the streets!
My 2c
Oh and also the Crowie Pub is just a hop skip and jump away for those who like to enjoy a ale or 2 :laugh:
Maybe Crows Nest???
My 2c
Oh and also the Crowie Pub is just a hop skip and jump away for those who like to enjoy a ale or 2 :)
That sound like a plan to me! and Italian places are usually fair big in size so can get a good table for a big group :laugh:
where did u guys end up going last month?
is that thread still on here?
We ended going to the Great Northern Pub as couldnt get into the Genki Noodle bar as very popular and dont let you book tables... A good place for a small group :laugh:
Pino's? nigga pahlease. if we are going pizza nthside. then it's got to be naremburn pizza. high qual, low price and bottle shop next door. :)
Thats actually a top idea - Parking shouldnt be tooooo bad at Naremburn either and the pizza is fantastic, plus we can sit either indoors or outdoors.
Maybe Crows Nest???
My 2c
Oh and also the Crowie Pub is just a hop skip and jump away for those who like to enjoy a ale or 2 :happy:
Pino's? nigga pahlease. if we are going pizza nthside. then it's got to be naremburn pizza. high qual, low price and bottle shop next door. :P
Im down with both of these :(
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
