Guest Boxhead
yeh i know it has nothing to do with skylines,
but in todays bunch of junk mail there was a motoring thing
had the new toyota SUV...
its basically a ute / 4wd....
looks like your new holdenish/ part ford...
what i read was its a supercharged v6, the supercharger is sourced form TRD usa, and its also 4wd... so should be nice, i wouldnt mind one...
if i or someone finds more info on the web, do share
https://www.sau.com.au/forums/topic/13723-new-toyota-ute/
Guest Boxhead
SPECIFICATIONS
Engine: Quad Cam 3.0-litre all-alloy V6, with VVT-i and supercharger
Transmission: Four-speed electronically controlled automatic
Driveline: Four-wheel drive with viscous-coupled centre differential
Steering: Power-assisted rack and pinion with variable gear ratio system
Front brakes: 355mm diameter ventilated discs with twin-piston calipers
Rear brakes: 343mm diameter ventilated discs with single-piston calipers
ABS: Four-channel, four-sensor
Front suspension: Independent struts with coil springs, hydraulic dampers and ball-joint linked stabiliser bar
Rear suspension: Torsion beam axle with coil springs, hydraulic dampers and internal stabiliser bar
Wheels: 19 x 8 aluminium alloy
Tyres: Dunlop 245/45 R 19
Overall Length: 4905mm
Overall Width: 1910mm
Overall Height: 1520mm
Wheelbase: 2870mm
Front track: 1610mm
Rear track: 1660mm
Kerb weight: 1710Kg
Seating capacity: 2
https://www.sau.com.au/forums/topic/13723-new-toyota-ute/#findComment-270833
ok got to give an A for trying lol sports utes aren't toyo's strong point in oz
looks like a como ute from the front & a fal from the rear
gee it looks like the tray has a lot of plastic in it,
ah I just have the motor for my SR5 Corolla lol :) :)
https://www.sau.com.au/forums/topic/13723-new-toyota-ute/#findComment-271464
