Wtb: Wheels For The Track
R3sp3ct
 Share
Hello,
I want to go to the track soon but im still on stockies. Does anyone have some cheap wheels that would go ok on the track??
They are for my R33
I HAVE SOME.. :happy:
17 x 9 front and 17 x 10 rear with tyres... will sell them to you for $350 plus deliv, im in tassie, these would be great for track, they are the perfect offset for teh r33 as they are on mine... no spacers needed... have a look
let me know
the pic of my car is availbel if you follow the link
http://www.skylinesaustralia.com/forums/in...howtopic=134504
Hi hi,
Im still after wheels as the other ones fell through.
Prefere anything around 255, i want width!
yeah sorry about that, im getting them repaired though, but like you said "you could find something for that price and not need to worry about the price."
My rims were 17x9 and 17x10 and have yokohama rubber on them and i was selling them to him for $400 delivered....
if anyone has somethign similiar for a similiar price then help this bloke out...
Beef
Hi,
I have a very track worthy set of rims and tyres
I know these fit GTST's perfectly as a few of them are using these rims on our trackdays :D
Also im selling them with semi slicks so you're ready to get out there and have some fun
Link is below for you
 Share
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
