Your thoughts,
While riding my bicycle home last night I had a brain wave, whether it being from lack of oxygen to it or something.
I am lead to believe (from information in this forum) that the series 1 turbo cannot be safely boosted above around 12 psi. This seems to be the weak point in the engine system to allow more boost as the usual way to increase boost would usually be a larger or hiflowed turbo. Would it be possible and economic to add another series 1 turbo (as it is relatively cheap 2nd hand) to the system so that both turbos do not have to work as hard to increase the boost to say 18-20 psi? Can the internals of the engine handle that?
Obviously, the following would need to be in place; larger intercooler, air intake, exhaust, upgraded fuel pump and injectors, and an engine management system.
What are your thoughts on this system, possible costs of the added turbo only, and any other constructive thoughts?
Mike
https://www.sau.com.au/forums/topic/13730-2nd-turbo-to-rb25det/
I think what your thinking of is like the system that those race trucks use where 1 turbo feeds boost into the 2nd turbo's intake thereby increasing the final boost the engine recieves, really wouldn't work on stock R33 turbo's though, and not practical for a street car.
Another idea would be to setup a 2nd turbo after the dump pipe of the first so that both turbo's recieve all the gas flow of 6 cyclinders, hence no extra lag but double the airflow, similar to the Supra twin turbo.
Yeh,
Like I said, it was one of those thoughts that may not have any substance as there was a lacking of oxygen from riding my bike. Just a thought tho'
A 4dr GTR would be great as the cars I buy are required to have certain criterias to be filled (due to the wife's demands) and 4 doors is one of them. Luckily boot space wasn't, but now is. Looks like this cars here to stay.
You can get 4 door GTR's but they cost a bomb. If you're after more power, just sell your old turbo for around $500 and buy a new Garrett for around $2500. It'll work out to be around the same cost as adding another turbo (assuming that's even possible).
Also, for some reason insurance companies don't like twin turbos put onto cars that didn't come that way from the factory. My insurance company don't care that I've got an aftermarket turbo on, but they wanted to be sure that I didn't put a twin setup on. They don't actually care what the single turbo is though! Can't wait until I can afford a T88 ;) For some stupid reason they seem to think that going from single to twin turbo makes it insanely powerful. I didn't bother telling him that it's often the other way around.
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
