Moving interstate cannot finish this one off!
Come and grab a bargain or trade me an R32 Skyline
1993 Nissan 180sx, SIL80
RB25DET conversion, RB20 box
BN Blister full kit
S14 seats
For more info, see nissansilvia
PM if interested
cheers
Edited by pssiii
https://www.sau.com.au/forums/topic/137300-sold/
to answer some of the FAQs, the car has been complied, is registered til Feb 07 and the conversion has been engineered and mod plated.
it's registered as a 6cyl, so snap it up while there's plenty of rego left!
https://www.sau.com.au/forums/topic/137300-sold/#findComment-2572521
do you have the details of what was done during the conversion?
my mate's looking for a sil80, but most of those he had seen were just bodykit conversions.
This isn't a genuine Sil80, it is a converted 180sx. It was bought already converted, but I believe it's still got the 180sx reo etc.
PM if your mate would like to check it out
Edited by pssiii
https://www.sau.com.au/forums/topic/137300-sold/#findComment-2607682
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
