My fault I was confusing him with QikStagea
i can see how that could have happened, pretty common mistake. ....or not.... lol
Why would they make different hinges for gtr and gtt? seems a lil bit odd, hey. Not interchangeable at all? Is it because of the different body width? Didnt realise that would effect the bonnet, thought it was just guards.
  • Replies 51
what brand guards are they? and where did you get them from? cost? do you have to put the gtr rad support in or are you just modifying it to fit???
Cheers ADRIAN
Guards are genuine Masa Motorsport from Japan. Cost was 45000yen pair, which ended up near $1100 delivered to Aust.
The guards will be copied soon and will sell for here at approx $450-500 pair.
Radiator support is R34 GTT/GTR and details of fitment are in the first post.
  • 1 month later...
  • 1 month later...
hows it going man the car looks wicked...
looks even better in the rear vision mirror though :P
have you still got the old front bar ifso is it for sale..
I still have the M'sFactory front bar for sale
PM me for further details
The radiator support is now welded in
Next step is to repaint the engine bay
  • 3 weeks later...
I have added some new pic's of my (slow) progress
Have fitted and painted the radiator support aswell as painting most of the engine bay with the engine still in
Had to remove engine bay wiring, brake lines, abs unit, brake booster etc
Came up really good esp compared to the factory paint job
Also half way thru fitting R34 GTT calipers and disc front and rear aswell as a manual gearbox conversion
  • 1 month later...
hows the progress goin darrin
The Engine bay is back together and car is drivable (around the yard)
The brake conversion is finished and the manual conversion just needs the gearbox swapped. pedals and hand brake done
Have just refitted front for final fit up and just need to finish mounting the front bar.
Then I can drive the car around on the road, un painted so I can get some exterior painting quotes
Before car is painted, I will get the manual gearbox in so mechanic's will not damage the paint
Will be getting the entire front and both complete sides and rear bar painted to tidy the car up.
Then can will fit the Apexi power FC and tune along with all the other mods incl turbo upgrade.
Mike,
I could send the brakes to you now if you want and the gearbox in a couple of weeks?
Brakes come with brand new pads front and rear aswell
Mike,
na just send altogether bro
  • 4 weeks later...
is she all painted up yet mate im dyin to see her when she is finished
No I have not touched the car for a month
I have been building a 3 1/2 car garage extension to the front house, which take up all my time. I only have 2 hands and I am not a builder.
The roof is half on now, so in a week or 2 I will have the roof finished so I can have some where to work on the car at night under lights durung the week.
I removed the factory door mirrors a week ago and fitted Ganador mirrors and found more rust hidden under the mirrors
You could not see any rust when the mirrors were fitted, but once removed I found a big hole.
I am dying to see it painted too, it has only been 18 months since I started this project.
Ps
I picked up a nice Apexi 420PS BB turbo the other day for it
Sounds like a big job Darrin, Congrats on the progress.
Why do all the good stageas have to be in Brissie or Perth :thumbsup: Haha. Sydney is catching up.. W00t!
How much has the project cost you so far(if you don't mind me asking)? and for the manual conversion by itself?
Dad and I completed a manual conversion last year on our R31 wagon, total cost was 1K after selling auto etc which was a pretty good 'investment' in our opinion! :)
Edited by StageaHoon
Front end parts only $4.5k plus paint and labour
Manual conversion with R33 GTR box $3K plus labour, could be done cheaper with R32 box
Very Nice.
R33 GTR boxes obviously dearer because 1. its a GTR and 2. High demand/hard to get?.
2 was an issue for us and dad needed good clutch for towing the boat so we ended up getting a heavy duty racing EXEDY item which also put the cost up(which also makes it quite the task to learn to drive with aswell.. :S I'll get there eventually), but we kept it down by performing the job ourselves over a long weekend. Dad is still to fit and connect up the manual computer.. better get on his back about it before he forgets again haha
Very Nice.
R33 gtr boxes are a little more. I got mine for a good price of $800
You can get r32 gtr boxes from $500 and GTS4 boxes for even less, but they are not as strong.
R33 and late 94 R32 boxes use a pull type clutch which cost twice as much as a push type clutch
I bought a s/hand pull clutch for $100 and then paid over $800 to rebuild it from Jim Berry - Race clutch.
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
    • Thanks for the details mate , for me I think being a daily driven and happy with a basic tune (630Nm and 310kw) . Seems to be working well I just put on a set of Michelin Pilot Sport 4 should help put the power down. I'm going to start looking a brakes and LSD in the future so I might reach out to you on options to upgrade the brakes. Cheers - Dee
    • I have a HR34 GT... RB20DE My speedo doesn't work! The rest of the gauges seem to work, fuel and RPM. I did not notice if my odometer was going up when driving last.  Any ideas? Speed sensor? Hopefully atleast... Gauge cluster perhaps? Or is that unlikely because the other gauges are working?   Any insight is appreciated. This is a rather new to me car. Lol
