Hi guys,
I bought a cheap catch can similar to the d1 or jspec cheapies with out a breather. I left it up to a friend to intall it for me.
On my RB25DET he sealed off the pcv to the inlet pipe before turbo, left the pcv valve and line from the side of the rocker cover to the inlet plenumm. the two rocker cover out lets he conntected to the catch can. This basically sealed in all crank case presure. I drove the car away after a few minutes a huge cloud of white smoke came out behind me while driving. i pulled over noticed the incorrect set up. It built up enough pressure that when i open the oil filler it was make a psssht noise releasing the pressure(while engine running). i took the car home and put it all back to standard.
However i now have a squeek noise from the front of the engine. It sounds like a faint squeeky belt. I notice this got louder when the engine could not breathe with the incorrect can set up.
What could i have damaged from too much pressure build up? i am guessing the cloud of white smoke was oil being passed thru the turbo seals, after i returned it to normal it is no longer blowing any white smoke.
The squeek noise wont go away and i think it may have casued some internal damamge? any ideas what it could have done? The car still runs fine other wise.
https://www.sau.com.au/forums/topic/137326-oil-catch-can-incorrect-install/
why do ppl not do a search about a simple catch can instilation's ive hurd so many ppl describe the above symptems.
it happens so often its not funny. i thought with all the wealth of information that is avalible then this stuff wouldnt happen
yes the dip stick is still there and did not pop out. Noise seems to have gone down now and the can is hooked up correctly.
I did search this forum extensivley- There is so much conflicting info on how ot install them and no clear way. The actual can came with very vague instructios.
SLIMVLT- do u know what out comes these symptoms havE?
Yeah a tutorial would be good, too much ambigous information in net forums regard catch can installs. I hope i havent damaged the egine internally. it is making that noise still at idle and its definenetly in the engine not the pullys.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
