Hi Guys,
I've just had some serious work done on my engine (series 2 gtst). I'm pretty sure the stock injectors have a purple colar, mine are brown and when tuning had to cut out alot of fuel, so i'm assuming they are after market, can some one help me work out what they are???
Cheers
https://www.sau.com.au/forums/topic/137327-help-me-identify-my-injectors/
As far as I know different manufacturers use different colour codes. And they sometimes change them with new models etc Then you can take an injector and have it hiflowed!!!
If they aren't at full duty cycle I wouldn't worry about it.
I'm not sure why you would need to know what the other mods were to identify the colours of the injectors.
For example, i know what most of the nismo collars etc are, but neither my mechanic or myself have seen this colour before, but so far seems to be getting heaps of fuel, so will have to wait and see when we tune her up.
well it will help get a rough idea if its a stock gtst then they will be stocker injectors as it will have a stock ecu, its not like you would have a stand alone ecu on a stock gtst with bigger injectors. if it has cams, stand alone, bigger turbo etc they a logic guess would be next step up say 550cc and if theres a resistor pack then GTR ones could also be a logical guess
Its quite simple really... If your running a highflow turbo pushing 20psi and still having to trim fuel then its obvious you have larger injectors.
You need to be a little more specific when describing your problems in the future. Give all the information you can if you want help and not get all secret about it when asked a question about it.
For example... how much power is it making, what other mods are done to the car when you bought it and what mods have you since done to it, where was fuel trimmed (idle, cruise, wot 2000rpm, wot 3000rpm wot high rpm where and by roughly how much)
We are all here to help each other.....
Yeah, sorry, no secrets to be had here, if there was i wouldn't have a build up thread. The simple answer is when i brought the car it was blown up due to hydrolic lock. So i've still never actually driven the car. When i got it it had AVCR, Power FC, Larger Fuel Pump, Turbo back 3inch, FMIC, Pod. So only some basic mods. I know from experience that most series 2 r33 injector collars are purple. Mine, as mentioned are brown. I thought someone may have come accross some brown ones, be they stock or aftermarket, and may have been able to identify them. So yeah nothing to hide, just that what i have done to the car has no bearing on what was previously fitted to the car, so nothing to hide, just didn't think it was relavent..
Again, if anyone might know that would be great. PS, the old owner didn't have any idea either....
Cheers
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
