Hey all, got out of work today and what do i find my door handle jammed up(the whole thing) and my lock destroyed. Thank god the little bastards didn't even get into the car but it is going to be a pain in the arse to replace/fix. If i came accross them i swear i would rip off there nuts and make them watch me grind them into mince meat.
Now i have that off my chest is there any place in adelaide that would be a start to look for new one? price?post-15951-1159963160.jpg
https://www.sau.com.au/forums/topic/137328-attempted-break-in/
Sorry to hear about it! You'd be surprised what a crash repairer could do with that .... I had my S15 fixed (had 50% the damage of yours) including respray door for $350. I would ask at Nissan dealers for the actual door handle and lock - should be easy to get (mine was fixable). Expect about $200 for handle and lock I would think.
Thanx guys, i will go see one of my dad's friends tomorrow before work see what he thinks at least you have given me a little hope that it might not be too bad. i'm also going to see if there is video on the carpark. i did find it funny that they hurt themselves in the process and left disgusting blood on my car.
^^^ I'm hearing ya, they touch ma car and i'll touch them! Also another reason to have a daily....... while my line is locked up under a car cover! working arvo shift in Plympton isn't the best place to be driving my car, espesially when i went out for 5 mins a few months back and noticed when i came back there was a car on fire down the end of the road!
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
