hoping someone will be able to help
i have an r32 gtr that is fairly stock and a mate of mine has a similar car (r32 gtr) but he has done a lot of work on the motor with forged pistons, heads, cams, power fc, intake, turbos, cooler and bullet proof bottom end. when dynoed it made 361kw at all four on a fairly conservitive tune. MY REAL QUESTION IS does anyone know what reading the knock sensor should read on a standard rb26 as he has done a lot of work and is getting a reading of about 40 in the power fc and thats under low boost . is this a safe reading or is this some thing that he should get looked at. i understand it may be a hard question to answer but any ideas would be greatly appriciated as he is scared to drive it as he dosent want to kill it . so it just sits in his shed what a waste.
any help would be great
thanks
https://www.sau.com.au/forums/topic/137341-engine-knock/
40 is acceptable if it doesnt go any higher... its not ideal... should be around the 20-30 mark... but 40 wouldnt bother me if i saw it on my H/C :P
can you suggest anyone in melbourne that is awsome at tuning the power fc to get the optimum out of the car?
https://www.sau.com.au/forums/topic/137341-engine-knock/#findComment-2558212
as ash said, 40 isn't bad.... normally anything under about 80 is considered acceptable. You have to remember that 80 is the peak knock and usually only happens for a split seccond, if you data-logged it you'd see it much lower.
Awesome at tuning a power FC in melbourne....... Ben @ Racepace, or you could try Nigel @ Racingline. Both in Melbs s.e suburbs.
https://www.sau.com.au/forums/topic/137341-engine-knock/#findComment-2559345
