Scotty you've gotta give me another ride in the GTR, see how it feels compared to my GTST.
Maybe if your a good little boy :P
when i get my new rotors in i will take ya for a drive, she doesnt stop too good these days :ninja: but that will be soon fixed!!!
Current Spec’s
GTR Front Bar
Vailside Side Skirts
GTR Rear Bumper Fins
Rays Drop Forged Aluminium Rims
Trust Intercooler
Apexi N1 Cat back exhaust
Blitz Pod Filter
Cusco Adjustable Coilovers (Track Spec)
Front Strut Brace
Exedy Heavy Duty Clutch
And lots of stickers!!!!!
Power on these specs was 137.9rwkw
Just added
Re chipped ECU (need to re-Dino for rwkw)
Future mods will be
A boost controller
A Dump pipe
An Aftermarket cat
High flow the standard turbo
Some gages
A Greedy tech Informeter
And some stereo gear
I only want about 180-200 rwkw
Ed say’s with that setup I shouldn’t have a prob getting 220rwkw if I get a bigger fuel pump.
555cc injectors,
Greddy Emanage
Greddy E-01
200kw atw. not much for you 6 cyl boys but itll be very quik for a 200 :(
Its in the shop atm getting kit, sprayed and repaired. god only knows when it will be done as he's takin his sweet goddam time. i met a fella on here who has a white 32 GTR there as well ;)
mind you that prolly wont happen as im going to sell it around my bday and either buy something else or pay out my loan and get a run around and start saving for house and other stuff :P
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
