just wanting to know what the standard fuel pressue an rb25det runs at?
what is the better fuel pressure to set an adj fuel pressure regulator at?
mods are fmic, turbo back 3" system, stock r33 ecu and fuel pump running stock 6psi boost for now...
Cheers, Matt..
Edited by rsx84
https://www.sau.com.au/forums/topic/137391-r33-fuel-rail-pressure-please/
1. just wanting to know what the standard fuel pressue an rb25det runs at?
2. what is the better fuel pressure to set an adj fuel pressure regulator at?
Cheers, Matt..
1. Standard fuel pressure is 34-36 psi (plus or minus boost/vacuum)
2. If you set it at higher pressure it will run richer. If you set it at lower pressure it will run leaner. Which do you want?
>_< cheers :happy:
  • 1 month later...
  • 3 months later...
How much extra psi of fuel pressure can be safely increased? I have 480cc injectors and wanting to know how much more cc's with the added increase?
to work out new fuel flow rate of a injector, take ur new fuel presure then divide it by your standard fuel pressure your injector was rated at, then find the sqaure root of that and then multiply your old injector fuel rating by the answer you got previously hope that makes sense :ninja:
sorry didnt realise this is an old post my bad
Edited by drf76
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
