In the last few days Ive noticed a clicking noise coming from my steering wheel everytime I turn the wheel. It is only noticable when turning it a fair bit like when parking etc, not when taking bends in the road.
It seems like it will make a clicking noise once - maybe once per full turn of the wheel?
When I go over a hard bump in the road you can hear it then too.
Sounds like something is loose. Maybe the mechanism that turns off the indicator after turning?
Ive taken off the steering column but cant see anything there where the noise is coming from.
It seems like its in the steering wheel itself.
Im just a bit worried about taking it appart - worried about the airbag going off in my face.
Has this happened to anyone before. Any ideas?
car is a 95 GTSt if it makes any difference
If your unsure on howto remove and check a steering wheel with an airbag attatched I suggest you take it to a god mechanic.
If an airbag accidentaly goes off when you playing around it can cause death.
I have seen this a TAFE videos (The really corny ones!)
Cheers
Josh
Is it a click or a light knocking sound? I had the same thing if it also happens over bumps.It is the metal plate that is in the wheel.It is vulcanized to a backing plate but the rubber gets old and breaks allowing the plate to flop around.I`m sure you could find someone to revulcanize it or maybe even glue it but I wasn`t sure if it had something to do with the air bag so I just bought a new one from just jap.$90:00.
yeah I guess it is more of a light knocking sound
thanks for that
I take it that you've got an airbag?
I own a S1 that doesn't have an airbag. I had a similar problem.
The plastic pressure plate that pushed down onto the horn contacts was the problem for me. The plastic went brittle and broke into bits and pieces and were rattling around inside the steering wheel whenever it was turned.
Had to pull the steering wheel cover off and remove what was left of the pressure plate. Although this meant that the horn no longer worked. I just had to find something to replace the pressure plate and hey presto, workin horn again :laugh:
Don't know how you'd go about if you've got an airbag though.
You might have the same prob.
Edit: Grammer
Edited by KeyMakeR33
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
