In the last few days Ive noticed a clicking noise coming from my steering wheel everytime I turn the wheel. It is only noticable when turning it a fair bit like when parking etc, not when taking bends in the road.
It seems like it will make a clicking noise once - maybe once per full turn of the wheel?
When I go over a hard bump in the road you can hear it then too.
Sounds like something is loose. Maybe the mechanism that turns off the indicator after turning?
Ive taken off the steering column but cant see anything there where the noise is coming from.
It seems like its in the steering wheel itself.
Im just a bit worried about taking it appart - worried about the airbag going off in my face.
Has this happened to anyone before. Any ideas?
car is a 95 GTSt if it makes any difference
If your unsure on howto remove and check a steering wheel with an airbag attatched I suggest you take it to a god mechanic.
If an airbag accidentaly goes off when you playing around it can cause death.
I have seen this a TAFE videos (The really corny ones!)
Cheers
Josh
Is it a click or a light knocking sound? I had the same thing if it also happens over bumps.It is the metal plate that is in the wheel.It is vulcanized to a backing plate but the rubber gets old and breaks allowing the plate to flop around.I`m sure you could find someone to revulcanize it or maybe even glue it but I wasn`t sure if it had something to do with the air bag so I just bought a new one from just jap.$90:00.
yeah I guess it is more of a light knocking sound
thanks for that
I take it that you've got an airbag?
I own a S1 that doesn't have an airbag. I had a similar problem.
The plastic pressure plate that pushed down onto the horn contacts was the problem for me. The plastic went brittle and broke into bits and pieces and were rattling around inside the steering wheel whenever it was turned.
Had to pull the steering wheel cover off and remove what was left of the pressure plate. Although this meant that the horn no longer worked. I just had to find something to replace the pressure plate and hey presto, workin horn again :laugh:
Don't know how you'd go about if you've got an airbag though.
You might have the same prob.
Edit: Grammer
Edited by KeyMakeR33
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
