In the last few days Ive noticed a clicking noise coming from my steering wheel everytime I turn the wheel. It is only noticable when turning it a fair bit like when parking etc, not when taking bends in the road.
It seems like it will make a clicking noise once - maybe once per full turn of the wheel?
When I go over a hard bump in the road you can hear it then too.
Sounds like something is loose. Maybe the mechanism that turns off the indicator after turning?
Ive taken off the steering column but cant see anything there where the noise is coming from.
It seems like its in the steering wheel itself.
Im just a bit worried about taking it appart - worried about the airbag going off in my face.
Has this happened to anyone before. Any ideas?
car is a 95 GTSt if it makes any difference
If your unsure on howto remove and check a steering wheel with an airbag attatched I suggest you take it to a god mechanic.
If an airbag accidentaly goes off when you playing around it can cause death.
I have seen this a TAFE videos (The really corny ones!)
Cheers
Josh
Is it a click or a light knocking sound? I had the same thing if it also happens over bumps.It is the metal plate that is in the wheel.It is vulcanized to a backing plate but the rubber gets old and breaks allowing the plate to flop around.I`m sure you could find someone to revulcanize it or maybe even glue it but I wasn`t sure if it had something to do with the air bag so I just bought a new one from just jap.$90:00.
yeah I guess it is more of a light knocking sound
thanks for that
I take it that you've got an airbag?
I own a S1 that doesn't have an airbag. I had a similar problem.
The plastic pressure plate that pushed down onto the horn contacts was the problem for me. The plastic went brittle and broke into bits and pieces and were rattling around inside the steering wheel whenever it was turned.
Had to pull the steering wheel cover off and remove what was left of the pressure plate. Although this meant that the horn no longer worked. I just had to find something to replace the pressure plate and hey presto, workin horn again :laugh:
Don't know how you'd go about if you've got an airbag though.
You might have the same prob.
Edit: Grammer
Edited by KeyMakeR33
    • I鈥檓 interested in the carbon diffuser fins and Toshiba MFD screen replacement if they鈥檙e still available.
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 馃檪
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
    • They aren't, but it depends on what interests you about an R32-R34. If it's the front engine I6 turbo that tunes well with a manual transmission an E92 335i 6MT is so incredibly cheap. You can get a super clean one for 20-25k USD tops. Put an LSD in it, tune it, have fun with it. If it's the general idea of AWD + turbo and a manual transmission the 996 Turbo is absolutely much more expensive, it's less practical but it's also basically a complete track-ready car from the factory. At least the Mezger doesn't have heaps of oil control issues. And in the US the 996 Turbo and R33 GTR are roughly the same price these days. 996 maybe a bit more now that the hype has abated for old Skylines here.
    • these are not the same
