Unlucky mate, I was planning to get a set of rims from Tempe but luckily my local guy is stocking them in a few weeks. I was glad because I'd save an hour trip but now I'm relieved that I didn't go there!
Anyhow heres a heads up, I saw a set of thos Velvets you're after going on NS.com so maybe these are cheaper for you.
http://www.nissansilvia.com/forums/index.p...7&hl=velvet
hey man
nar its cool im gettin mine band new for 1500, 250 more then the wheels from tempe, but i dont mind, he had a set in stock he was gunna sell to me for the same price 1250, but the ofset was for a commo. to bad ey
my tyre guy ordered a set for me but they were 250 more but i dont mind payin that for a much better wheel then those gold ones.
still 1500 is cheap as chips
I hope your tyre guy is getting his money back if he was the one who purchased the rims?
I personally would only get quality japanese or european rims. At least they will be strong and better built than most of the crap that is sold here at places like Bob Jane and Tempe, etc, etc.
yeah man
it was tyre factory tingalpa phone number is 3890 5222
yeah he did get his money back or is in the process of
most of the rims in australia are made in japan anyway, just the quality is crap, and good rims cost a bundle and im not takin my car on the track so no need for super light weights or mega wide anyway.
im still getting the anz wheels and they are cold pressed which make them strong and light. im going through jax at slack creek and gettin em for 1800 but with the sale of my standards at 450 i am gettin em for 1350 so thats pritty good
hey all
i finally got my rims today i got 19x8.5 all round, was gunna go 19x9.5 on the rear but it was illegal looked so hawt tho.
they are koya race black with machined lip pics will be up soon
i got em for 2200 with tyres and wheel alignment
so not to bad with the sale of my standards of 450
an extra 300 then what i was originally goin to pay for the gold ones from tempe
so it all worked out in the end and im happy
like i said pics soon once i get a digi cam
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
