Importing From England?
I am currently weighing up the cost of importing a 1995 r33 gtr from england. Although who im buying it off has offered to pay for shipping. I just want to know if i am able to import it and what i will have to do for compliance, if i have to? thanks guys. Ps. I am from Victoria
Edited by dodge
I think you'll have trouble getting info out of any one here for that as Skylines typically hail from JAPAN!!! [/sarcasm]
Maybe you should check for a forum for importing pommy cars. Not sure what they import though, maybe mini's?
Have you checked out importing from japan?
Why England? Cost???
Basicly because i am getting it cheap and he is offering to pay for shipment over. I am an absolute n00b when it comes to importation, with this 15 year rule business and stuff and this car is 11 as its a 95. To mae it basic im just wondering what i import it under, and once it lands what i need to do to get it on the road here and if i could get a rough estimate that would be great. thanks heaps
Exactly the same as importing from Japan. You would be importing under SEVS. Look at the stickied thread at the top of the imports section for the link to 'VSB 10' on the DOTARS website. It will tell you everything you need to know in regards to the process.
Thanks that is a big help. Im still finding it a bit hard to grasp but understand alot more. For those of you tha have imported from japan, what does it cost to get the import aproved, so excluding shipping and compliance? thanks guys your a big help
The costs payable:
Import Approval fee = $50
Shipping =
Customs Duty = 15% of cost of car
GST = 10% of (cost of car +customs duty + shipping & insurance costs)
Quarantine costs = approx $88 (+ re-inspection costs and cleaning if required)
I was in the UK 10 years ago and was looking at importing cars, I seem to recall the rule there of a 50% custom duty on value of car unless you had owned and have prove of ownership for 12 months, then it drops to around 15% or 0%
May have changed now, but something to check :)
Edited by PSI_GTSII
its silly to import to australia a japanese car that has been grey imported into the UK in the first place. Basically you'll be doubling up on taxes etc (the owner would have paid it first when they brought it into the UK, then when the car arrives in AU you'll have to pay it again). So much cheaper, simpler and easier to get a car straight out of japan, esp with R33 GTR's being landed and complied for around the $25,000 mark these days.
If you were to go thru a broker or a compliance workshop for a car in Japan, they'd handle finding the car for you and organise for it to be shipped, and complianced. All that you'd have to is pay for the costs that are incurred and pick the car up from the compliancer, take it to VICRoads and register the car. Its a somewhat hassle free process.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
