I am selling my setup.
Genuine 'nos' brand.
Kit has:
10lb bottle (empty now) - mat blue
2 x foggers (for twin throttles)
50rwhp jets
all braided lines required for install
'nos' bottle pressure gauge
mounting brackets for bottle
solenoids and relay
Ready to install which is quite easy.
You don't need a re-map as this is a wet kit and only runs a 50rwhp jet. I used it on the dyno and my AF was virtually unchanged, actually slightly richer from memory and gave me ~35rwkw gain.
Selling because I am probably going with a dry kit after my rebuild is complete and run in.
This kit sells online delivered for $995 anywhere in australia and I am asking $800.
Kit has general wear and tear from being put on and off several times.
Located in Melbourne
pm or sms me 0402383944
https://www.sau.com.au/forums/topic/137457-fs-10lb-nitrous-wet-kit-nos/
I only have pics of it installed, haven't taken any of it out of the car. If you would like some just send me an email to h1p_h0p 'at' hotmail.com
Larger jets can be bought for about $5 and the kit has previously had 200hp jets in it. I think 300hp is the max for this kit.
The purge valve can be bought for about $100-120, but you can purge it with the car off before you run and it stays purged until you disconnect the bottle.
can you use larger jets?
has this kit got a seperate solinoid so you can purge?
  • 3 weeks later...
  • 1 year later...
Got mine from Vpw for just over $900 150hp kit with bottle blanket, purge kit, fogger nozzle, high flow valve, high flow filter, pressure guage and freight to Tassie
yeh but u suck ass...
P.S hook a brother up? :verymad:
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
