I am selling my setup.
Genuine 'nos' brand.
Kit has:
10lb bottle (empty now) - mat blue
2 x foggers (for twin throttles)
50rwhp jets
all braided lines required for install
'nos' bottle pressure gauge
mounting brackets for bottle
solenoids and relay
Ready to install which is quite easy.
You don't need a re-map as this is a wet kit and only runs a 50rwhp jet. I used it on the dyno and my AF was virtually unchanged, actually slightly richer from memory and gave me ~35rwkw gain.
Selling because I am probably going with a dry kit after my rebuild is complete and run in.
This kit sells online delivered for $995 anywhere in australia and I am asking $800.
Kit has general wear and tear from being put on and off several times.
Located in Melbourne
pm or sms me 0402383944
https://www.sau.com.au/forums/topic/137457-fs-10lb-nitrous-wet-kit-nos/
I only have pics of it installed, haven't taken any of it out of the car. If you would like some just send me an email to h1p_h0p 'at' hotmail.com
Larger jets can be bought for about $5 and the kit has previously had 200hp jets in it. I think 300hp is the max for this kit.
The purge valve can be bought for about $100-120, but you can purge it with the car off before you run and it stays purged until you disconnect the bottle.
can you use larger jets?
has this kit got a seperate solinoid so you can purge?
  • 3 weeks later...
  • 1 year later...
Got mine from Vpw for just over $900 150hp kit with bottle blanket, purge kit, fogger nozzle, high flow valve, high flow filter, pressure guage and freight to Tassie
yeh but u suck ass...
P.S hook a brother up? :verymad:
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
