It depends. If you choose not to put a cat, then yes it is going to be loud. I got a 3-3/4 inch pipe all the way through with with a big tip, and it doesn't sound loud at all. It makes deep, bassy sounds, naturally, more than standard system. But not that loud. The thing is, I put two cats in there. One at the original spot and another one somewhere near the fuel tank.
https://www.sau.com.au/forums/topic/13748-how-loud/#findComment-271726
Guest INASNT
y did u put a big exhaust on and then put on 2 cats?
the cats are the most restrictive parts of the exhaust!
https://www.sau.com.au/forums/topic/13748-how-loud/#findComment-273793
if you were concerned about noise then why didnt you just put 2 resonators in? two cats... WTF?
https://www.sau.com.au/forums/topic/13748-how-loud/#findComment-274620
yes. yes you get flames. Big flames. about 3 feet long, a nice orange blue... stainless dump, trust front, trust 'racing cat' :), 4" trust to straight through system... standard ECU. Between gears 1-2 and 2-3 at night the whole surrounding area lights up like a lightening strike... of course i now have a cat
PS loud... try 102dB on for size at 3000rpm, imagine at redline!
https://www.sau.com.au/forums/topic/13748-how-loud/#findComment-274717
Bigger exhaust does not allways produce more power. As with most things, once you exceed a certain size, it is pointless going bigger. A freind took off his 3" exhaust from the turbo/dump pipe, at the drags last year, and he lost 0.1 of a second
https://www.sau.com.au/forums/topic/13748-how-loud/#findComment-275937
Guest INASNT
Originally posted by aybee
most cars out there are running undersized exhausts. ive been told that a car running around 300 rwkw should have a 5 inch exhaust. theres a few cars running that power but i doubt there running that exhaust size.
pffft 5inch exhaust!
who da *** told u that crap
https://www.sau.com.au/forums/topic/13748-how-loud/#findComment-279575
If there are alot of cars running that type of power, with only a 3" or 3.5" exhaust, it obviously not required to have a 5". So many w/shops can't be wrong, the person who told you that either has no idea about turbo cars or is talking 5h1t. What it an exhaust place, trying to drum up some extra cash?
https://www.sau.com.au/forums/topic/13748-how-loud/#findComment-279679
A lot of things could cause that kind of miss at the strip.  It could be a bad launch or something.  I do not think exhaust system would only affect 0.1 sec, Dude!
I have to agree with you 100%. What i should have also wrote was that the only difference the owner felt was the extra "lag/sluggishness" off boost. I guess the only way to tell is by getting the car on a dyno and doing a few runs with ex. and a few without.
https://www.sau.com.au/forums/topic/13748-how-loud/#findComment-279695
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
