unfortunately she did not win the Ralph competition, they rigged it cos we saw the final vote and she was thousands ahead!!!
but while she was in that comp she found out bout FHM and she did the photo shoot last week (got back monday), so imguessing she will be in the next edition... i know wat shes wearrrrrrrrrrringggggggggg :pirate:
  • Replies 108
Posted Images
yeh well she was over 20 thousand votes ahead, but anyways we found out they dont actually do a shoot for that competition anyway u just go in the competition to win girl next door of the year and then if u win that u get to do a photo shoot,where as FHM just took her on anyways and they did an interview with her and flew her to syd for the photo shoot in a pizza shop lol
    • Yeah good point, it won't flash on indicator that way, so plan B, just another wire to run from under the dash which makes it a bigger job 30 to indicator + globe side 86 tapped into 12v input to flasher relay under the dash (has 12v when indicators on, nothing when no indicators) 87a to headlight parker + 87 to original indicator + chassis side 85 to chassis/earth Now it will flash with indicators and be solid on with parkers
    • FWIW, that's the only colour I'd buy it in
    • I am having issues I believe with the throttle body. The butterflies only open about 1mm on the bench at full throttle. Is this what is supposed to happen? does it use the motor for the rest? I am able to manually open them up the hole way but it sounds like it is on gears.
    • Currently at 380rwkw with 2860 -5's & b cams on e85, trying to make it have a bit more torque/usable power down low.    Ive googled the v cams and most sites say discontinued, is there anywhere you can still get them?
    • Most hardlines are available new still. But unless they're rusted to the point of needing replacement you can just zinc or cadmium plate them to keep them going for decades to come. Regarding the turbo drains it really depends. Braided lines might be better if it's a straighter path than OEM but I would not assume braided teflon lines will never leak. Teflon is a very durable material but you can still abrade, erode, or otherwise compromise its integrity. The return hoses on the bright side are not that hard to access relative to a full turbo removal so if things go wrong you can always put it back to stock. You can very easily drive yourself insane analyzing every little change, or maybe that's just me.
