Have any one install msd on their r33? If so what model? What mods did you do?
I have asked their tech peeps and said that I would be able to use msd if I was able to seperate the coilpack from the amplifier. Is the amplifier same as the igniter (the box that sits on to of the coil cover)? Any help or feedback is appreciated thanks
The only way that you can use any of our products, is if you can separate the coil from the amplifier. If you attempt to install any of our equipment without separating the two from each other you will just end up damaging your ignition system. Here is a diagram explaining what I am talking about.
Edited by mlyf16
https://www.sau.com.au/forums/topic/137489-will-msd-work-on-r33/
this is sonthing i wanted to post up a while ago. i am also interested in this, for runnign a nitrous system, the DIS is what i was told to use by a friend of mine. Is there a DIS 6 available??. i want to use a big shot nitrous sytem on my car, and after doing some reading about the DIS sytem, it featured a nitrous retard. also is it true what i hear about when sitting at the starting lane of the dragstrip, you can use a ignition retard to spool the turbo earlier and launch at full boost???. i heard al of this and want to be sure of it. and also after doing some more reading, thats why i am asking if the DIS 6 exists, i read that the DIS 4 is built to cope with 6cyl engines utilizing a 3 coil setup (hence they are running waste spark) or 8 cyl engines running a 4 coil setup. i dont see how a skyline would fit into this equation. please all you sky guru's :) out there shed some light
Yeah!! You can run both dis4 and dis2 if ur not running the waste spark system.But need to seperate the coil from the amp. NOw how can you seperate the amp from the coil pack? Is the amp from the diagram same as the ignitor found on top of the coilpack cover?
Msd tech just told me this """""You are not eliminating the amplifier to use the DIS-4.You are taking the signal from the amplifier and stepping it up to the coil with the MSD equipment. You still have to retain the use of the amplifier to trigger the MSD box. The reason you can not install the MSD unit before the amplifier is because the amplifier is equipped with a ower transistor that will not be able to handle the high output voltage of the MSD equipment. """
Hope this help!!
so what you guys are saying is that i would need a DIS 4 and a DIS 2 ignition system?? and separate my amplifier from my coilpack loom and splice the MSD in between them. that would bring with it that both units need to be configured on the same settings. and how would this ignition thing work with a PFC (what i am running in my car). and is it possible to configure a PFC for big nitorus use (ie creating a separate map for nitrous usage), if this is so, i could eliminate the use of a separate ignition system. is want to shot about a 150HP shot of nitrous into my engine. (will be deliverd by a Nitrous Xpress direct port system. i would be using it for my actual run, but i see it as a bit of insurance, you know when you begin to dee the other guy in you rear view at the strip, you always can count on that little button. that why i would need some sort of a high speed retard for the big shot of nitrous.
Although i have never seen one, Im of the opinion that dis6's do exist, however you can use a dis4 and set it up with waste spark using the original coils, dont know haw long thay would last, although in theory CDI places less load on the coils. You need to intercept the signal between the ignitor at the back of the head and either intercept the signal for all six (dis6) or pair the coils if using a dis4, 1&6, 2&5, 3&4. PFC will run it fine although it wont have separate maps for nos. HKS sell a twin spark CDI unit for about $800 which plugs straight in(with the appropriate patch loom)
    • I went from stupid 600+HP setup, to an NA Barra in mine...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
