hey I am spraying my car in a few weeks and im still trying to decide if i want put an aftermarket front bar on e.g. 400r gtr ect just wanting to no if its just going to scrape eveytime i go in a drive way or go over a speed hum or wot ever cars lowered not crazy low but id say 1.5 2 inches from standard any advice would be good did a search but couldn't find any thing I just don鈥檛 want to spry it then have to do it again the 1st time I drive it
regards dave
https://www.sau.com.au/forums/topic/137566-front-bar-gutters-speed-humps/
Fibreglass is a ridiculous material to make front bars out of, every one who has them has complained that they crack, or the mounting points break, on a lowered car you're just getting that much closer to wrecking one, there other materials that do a better job, MDF I think its called.
i have a fibreglass front bar, and my car is lowered. i bought the bar from a wreckers cheap cause it was stuffed. we just patched it up and put it on, but we also reinforced the base of it cause we knew it was going to scrub out. it hasn't cracked yet <touches wood>.
Haha, FRP is still a fiberglass product. Pretty much all aftermarket front bars are made from fiberglass.
O and I mite add have you ever tried to repair a smashed/broken Oem/plastic front bar mate? I'll take the fiberglass to repair thanks.
Edited by Silent
regards dave
I think mine is lowered 1.5 inches, and with the 400R bar on, it is 100mm in most places. (Legal in NSW).
Yes it scrapes on speedhumps.
Yes it scrapes on driveways.
Yes you have to take everything at an angle.
After a few weeks you learn what is too big and what it can handle. My bar is hard but is flexible and I can put money on it that being a bit flexible has saved it from snapping a few times.
    • Not alot of room in the front or mid pipe to play with Helmholtz chambers, plus they are pretty hit and miss getting the length and volume right, and time is money when it comes to trial and error testing at a exhaust shop, it isn't like test fitting mufflers or resonators From previous experience with exhausts and trying to tone down the volume and eliminate some drone, a resonator in the mid pipe typically make it much better,  and even possibly stop Jackie complaining about it, me, I really don't notice it that much, but, I am pretty deaf 馃ぃ
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30掳bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • www.rollracing.com.au tickets aren鈥檛 live yet
