hey I am spraying my car in a few weeks and im still trying to decide if i want put an aftermarket front bar on e.g. 400r gtr ect just wanting to no if its just going to scrape eveytime i go in a drive way or go over a speed hum or wot ever cars lowered not crazy low but id say 1.5 2 inches from standard any advice would be good did a search but couldn't find any thing I just don’t want to spry it then have to do it again the 1st time I drive it
regards dave
https://www.sau.com.au/forums/topic/137566-front-bar-gutters-speed-humps/
Fibreglass is a ridiculous material to make front bars out of, every one who has them has complained that they crack, or the mounting points break, on a lowered car you're just getting that much closer to wrecking one, there other materials that do a better job, MDF I think its called.
i have a fibreglass front bar, and my car is lowered. i bought the bar from a wreckers cheap cause it was stuffed. we just patched it up and put it on, but we also reinforced the base of it cause we knew it was going to scrub out. it hasn't cracked yet <touches wood>.
Haha, FRP is still a fiberglass product. Pretty much all aftermarket front bars are made from fiberglass.
O and I mite add have you ever tried to repair a smashed/broken Oem/plastic front bar mate? I'll take the fiberglass to repair thanks.
Edited by Silent
regards dave
I think mine is lowered 1.5 inches, and with the 400R bar on, it is 100mm in most places. (Legal in NSW).
Yes it scrapes on speedhumps.
Yes it scrapes on driveways.
Yes you have to take everything at an angle.
After a few weeks you learn what is too big and what it can handle. My bar is hard but is flexible and I can put money on it that being a bit flexible has saved it from snapping a few times.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
