These r Skyline R34 stock wheels they r 16" inch wheels, i have upgraded wheels to a bigger size and i have no need for these anymore, 2 rims r in perfect condition the other 2 have gutter marks as u can see in the piks, the tires r ok and will pass for rego, they have approximatly 20%-50% percent tread left as u can see, im after $550
https://www.sau.com.au/forums/topic/137604-16-r34-rims-stock-wheels/
standard r34 rims are 17x7.5width..cheers these arnt standard r34rims
cheers
They are R34 rims
Come on some base model 4 door R34 sedans and series 2 Stagea, I also have a set of these lying around
They are R34 rims
thank u buddy these ppl dont know wat there talking bout get ur facts 100% right b4 writing a post
price drop $500
there is a chip in the third wheel still drives fine perfect in fact
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
