i have 2 x 15" 1000 watt rms subs with stupidly big magnets connected to them which i have to install, atm i only have one in in a fairly large box, which i needed to remove my spare tyre to get in, i havnt looked far into the boxes yet, just wandering if anyone knew if i could get a dual 15" box which would fit strait in or even 2x boxes, and keep in mind they cant be too shallow thx in advance
https://www.sau.com.au/forums/topic/137648-big-sub-setup-in-r32/
so your saying i should make 2x 15" holes in my bootlid and mount them in? genious!!
now serious help please, i know its a bit ridiculous but i had 2x 12" alum 1000 watt rms subs and i duno... just didnt have the deep low rumble i like, i know it will fit all i wanted to know was if any body knew any boxes which would fit strait in, to try make life easier for me before i go to the effort to make one myself or get one custom made depending on how lazy im feeling
Edited by nemz
short of removeing the rear seat that is the only realy way I can see 2 15" subs in there properly.
hahah yeh i have my new body kit on its way here now finally completed and my car is gone till jan 10th :) im spewing man, i cant beleive my car got impounded for a measly little chirpy into second gear.. and yeah all that gear did go in
list of it goes
1x 1 farad capacitor(soon to have an extra 4 farad for sub amp)
1x earthquake 900.5 amp for speakers
1x lanzar 4000 watt mxa 282 amp 2 channel sub amp(if you dont know who lanzar is, its made in the usa by boston acoustics)
2x audiopipe 1000 watt rms 15" dual 2.5 inch voice coil subs
the lanzar amp takes up the whole length of the back of the seat, and earthquake which is pictured as the blue amp in that pic takes up the rhs and the box is a shall box which takes up the whole height of my boot and almost width and lenght so yeh when you open all you can see is system and no floor, it was a bit messy but will re wire and stuff to make it look better when i get the car back
speakers
- earthquake 400 watt 5x7 in doors with tweeters
- earthquake 600 watt 6.5" splits in rear
deck
- pioneer deh-p5750mp
3x 5v pre out with full sub control + multiple amp control
mp3,wma etc
remote
wires
dual 4 guage wires with gold plated terminal
100 amp fuse
3x cadence rca's (i wouldnt recomend these im changing very soon)
12 guage oxygen sealed speaker wires all around
dB rating? not sure yet but will try find out some time soon
what a list.
Ive never tried to fit a 15'' let alone 2 of them.2guup has 2 12's that are a tite fit.i dont rate ur chances of fitting them.
All i could suggest is that you tear out the whole stock boot trim and start from there.make the spare tyre well one hole 4 the sub.but remember u have a huge magnet so make sure the metal in the boot dont interfere.hey! the second sub you could mount like a step.free air would be ur best option n use the boot as the box 4 da home made!!
thats a hektik install in that pic, team lets put an amp through a sub going too fast around a corner....
oh and if your car got impounded, take it to court, get some good legal representation and you might be suprised..
  • 2 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
