Hey,
Went down to Malaga in Perth today and got my car put on the Dyno. It was a dyno shoot out day so there was alot of other cars getting tested. The other R32 Skylines were pulling around 140kw max and my mates R32 with a RB25DET pulled 197kw.
The mods I have on my car are:
R34 Turbo running on 12psi
FMIC
K&N Air Pod
Lighten Flywheel
3 and 1/2 inch Cat back
And i Pulled 196.4kw!!!!
Everyone couldnt believe it so we tested it again and same result! Im very happy with my RB20!!!!
https://www.sau.com.au/forums/topic/137660-dyno-run/
  • Replies 58
I was the dark blue R32 there... I wasn't too impressed with my ECU :)
My AFR's started in the mids 11's and dropped down to 10 :D
With a lot of leaning out I should get up to 160rwkw (from 140) with the stock turbo.
Are you still running the stock ECU? I think mine just hates me
Yet more money to throw at the car :dry:
https://www.sau.com.au/forums/topic/137660-dyno-run/#findComment-2563553
I have always known the RB20's needing quite a bit of work to push them over the 200rw/kw... Thats an excellent figure for such little mods... would love to see the dyno print out with AFR... how does the power curve look?
Cheers
https://www.sau.com.au/forums/topic/137660-dyno-run/#findComment-2564265
Half and exhaust and no tune and you made 196rwkw
That as you is above the norm for an rb20! Most will only make 10hp more MAX with a full zorst and tune (rb20 with rb25 turbo).
Your ecu must be running the car quiet well and the motor sounds pretty healthy :whistling:
https://www.sau.com.au/forums/topic/137660-dyno-run/#findComment-2564489
questioning what seems above average is human nature...
of course if the person posts up a dyno graph for us to look at then i'd be happy to say well done and begin some great discussion as to the legend that the 'ol rb20 is :ninja:
i personally think it may have been misread to be kw when his graph was in hp
https://www.sau.com.au/forums/topic/137660-dyno-run/#findComment-2564839
Woops! Though I had put up the graph!
And it is in rwkw not rwhp!!
Its a stock ECU and hasnt been changed, unless the guy before me got it remapped and didnt tell me. Its running a bit lean but its properly because im still running a stock fuel pump.
RB20 Power!!!!
Was having trouble uploading the pic so the graph is at this link:
http://www.photodump.com/viewer/r32matt/DynoResults922.html
Edited by r32matt
https://www.sau.com.au/forums/topic/137660-dyno-run/#findComment-2565373
    • Nah, you failed to pay your washer cover subscription and BMW have revoked your access.
    • Haha thanks Lith,  So it's currently working quite well and the torque reduction is setup and working phenomenal. It also got a custom torque convertor from All Fast in WA. Stall speed somewhere around 5500rpm unlocked but still with the lockup. The car went back onto the dyno after a 3yr hiatus (even with the dbw, and other mods completed in this time) managed to make ~515kw at all 4 hubs. Sean setup the Torque reduction which now sounds awesome and working well. We setup adjustable torque controlled launch control aswell.  Man what a feature. Especially when drag racing on street tyres I Managed to get out to the drags late last year and tick a huge bucket list item off of running mine and the cars first 9. Car went a 9.98 @142 Still had the young fellas car seat in the back aswell.  This was on 255/40/17 Nankang AR-1.  Currently the Turbolamik is still completing it's own torque calcs and managing shift times from there. Unfortunately emtrons can export is still a little restrictive to export the ecu calculated torque just yet but I have recently been suggested a work around that I just haven't had a chance to trial yet.
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
