I only dyno when I feel a difference in performance or when I have added a mod that could affect AFR's.
Or unless your car starts pinging.
Don't think there is really a need for it every 6 months if there isn't any difference in performance.
Cheers
Josh
Cheers
Josh
i normally do at least a power run every 6 months or so - just to check (R32 GTR with ~300awkw)
it's only $120 - which is way cheaper that a new bottom end :D
Mine is generally (when running) on the dyno around every 3-6 months.
Each time it goes in for a service (5,000kms), quick run up to check everything.
If your running a more standard car, then ever 10,000 IMO would be a good idea.
If its dead stock - once a year.
If your smart, nip onto a dyno day. Will probably cost ya $40 for a run or two and that will check mostly everything for a pretty cheap sum
