Aussie made cars and V8's only - dont get me wrong I think this gr8 and quite spectacular to watch, I'm a big fan of the V8 Supercars.
Initially I beleive it changed to this because the Aussie made cars couldn't get a look in, and it has grown into THE premier event.
What can we do to get the HPI's into the same level in Australia ? Sure we have heaps of little events but they hardly get mentioned on the same scale.
Nothing can be done
v8 supercars sucks all the money out of the sport
No one in the field deserved the win more than lowndsey, he was the closest to Brock out of everyone.
what about the 300C??? everytime I turned around to see what was going on he was leading... he definitely deserved to win!
yeah, i was cheering that courtney beat ingall to the line for a much deserved 3rd place for seto + JC. lowndes is a champ and it's surprising that it's only his 2nd bathurst win. I was sorry to see skaife out early though. I love to watch him drive, and would have been happy if he had won too.
I pose this question to you all. As the Clerk of the course elected to continue the race under a green flag when Jason Richards stuck it into the wall at Mcphillamy when a previous full course yellow was used for another crash incident at exactly the same place, had Kelly been able to jump Lowndes and take the win, would we have seen all sorts of legal challenges because a precedent had already been set? Lowndes was leading by a substantial margin at that time and was reined in under the yellows.
There ya go troopers, debate that one! I know that if it had been me I would be looking for someones head.
yes very interesting decision especially in light of the proven dangers of the track that weekend. Safety should always come first...but did this become a commercial decision instead? was there presure from avesco?
Definitely a commercial decision. Teams didn't spend millions, fans didn't travel 1000's of km's and drivers didn't race 158 laps only to finish doing 60km/h behind the ugliest sounding car the planet has ever produced.
I'll have the entire Top10 + Race + presentation on 4 dvd's by tomorrow arvo :)
Hmmmmmmmm....very interesting isn't it! I would hate to think what might have happened if someone had t-boned JR's commode and more tragedy occurred! A very strange decision given that they yellow flagged the race when JR's car had gone straight ahead at the Chase and was not in the slightest bit of danger! Hmmmmm......conspiracy theories abound!
Edited by Muz
Tim Jenkins the race director makes this call and saves the race finishing under yellow-all drivers were told JR was there by crew chiefs on the radio and a local yellow was in place-with only a couple laps tp go it was decided that this would be ok - if it was more laps it would have been a full yellow with more SC laps
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
