hey guys,
i know this is gonna sound stupid but here goes anyway.....
- i got the old hks sequential bov and it doesnt go off sometimes even though im hitting boost.
- should i be getting more bosst with the following mods :
- fmic
- pod
- exhaust, front pipe + hi flow cat
- bov
doesnt the boost automaticlly goes up with an exhaust by one or two psi. Right now im my boost gauge doesnt read more than 5 psi, no matter how hard i drive. One of my friends told me that the extra boost is lost in the fmic. Could he be right or is something wrong with my engine or turbo. Should i get my car check out.
thanks in advance and happy boosting
https://www.sau.com.au/forums/topic/13772-bov-and-boost/
Unless you've got a hole in your FMIC you won't be loosing any boost.
Some people report on having more lag with a bigger intercooler, but I never expreianced it with my 700x300x76 cooler.
Are you reading it from the factory boost gauge in the dash or do you have an aftermarket gauge???
Just remember that the in dahs boost gauge doesn't read in psi.
Maybe the HKS BOV needs a slight lube up with a little bit of grease?? Do you still have the hose conected to the top of the BOV???
J
https://www.sau.com.au/forums/topic/13772-bov-and-boost/#findComment-272898
i have a apex boost boost which reads in x100kpa( same as the in dash...i think ). Even when i drive it hard, the boost wont go past .05 on the apex or in the dash boost gauge. The intercooler is ok.
are you talking about the hose connected to the factory bov, if you are...... no its not there anymore. Will this affect the HKS bov.
how do go about lubing up a bov
do you think theres something wrong with the car
thanks for your reply and advice
https://www.sau.com.au/forums/topic/13772-bov-and-boost/#findComment-273704
Depending on how you've got it plumbed up will depend on how many hoses you'll have.
I'm pretty sure the one that you've got vents out to the air.
The hose that should always be connected is the small hose that is connected to the top of the BOV and goes to the inlet plenum.
This will hold the BOV close when under boost, and also help pull it open when your between gears.
If you can, take a pic of the BOV on your car and we'll have a look at it.
Cheers
J
https://www.sau.com.au/forums/topic/13772-bov-and-boost/#findComment-274511
factory boost solenoid limits the boost to about 7psi.
It is quite possible that this is the problem, it self corrects.
You can try and reset the ecu (Disconnect the battery overnight).
Otherwise the only way to assure a 10psi level of boost is to buy a proper boost controller.
https://www.sau.com.au/forums/topic/13772-bov-and-boost/#findComment-280754
the car is fine........
it was just my paraniod nature.The reading in the gauges were in bars so .5bars = 7psi( man i feel stupid )
hey rev210,
the mechanic at the dealer told me the same thing( factory boost limited to 7psi ). When you reset the ecu, do you drive it as usual afterwards or drive it hard
thanks for all your concerns and happy boosting
https://www.sau.com.au/forums/topic/13772-bov-and-boost/#findComment-283520
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
