Hey guys.. I got an r32 skyline,
Noticed yesterday car wasnt very as powerful as it has been (in the last couple of weeks). Im pretty sure I have a boost leak somewhere but im just after the stock boost level of a r32 gtst. On the stock gauge it reads about 5 and then dips down to 4.5 or 4psi.. im dead set it usually runs about 7.5
Anyone with any ideas please let me know.
Michael
https://www.sau.com.au/forums/topic/137726-stock-r32-boost-levels/
dont go too much boost, turbo will chuck a hissy fit lol :)
Mine was fine on 16psi for quite some time. Still is fine now; it has a little to do with luck of the draw, and how well the motor has been tuned with regards to NO detonation, mixtures are not lean and most importantly how hard its driven.
Yeah its strange how some people say its crazy to boost a R32 turbo over 12 psi but I know of one guy whose been running his stock turbo on 18psi since he imported the car 5 years ago and it hasnt missed a beat once!
slightly off topic, i've been running my 33 at 14psi on the stock turbo for a few months now. haven't had any issues. people say they lose power after 12psi due to the turbo being out of its efficiency range, but 14psi feels faster than 12. i put it down to about 11psi for a few weeks, and it just felt dead.
Yeah I know what you mean my car made 166 RWKW on 14 PSI but Unigroup put it up to 18 to see how much more power it would make and it made close to 180 RWKW. (stock turbo)
I think what people mean is top end peak power doesn't increase much past 12psi.
The gains to be had by upping boost are through the mid range which essentially accelerates you quicker to the peak power. So.. the car feels quicker. :wave:
if i only fang it up through the gears at high rpm it feels great. i think the problem is that so many people hear that it is bad to run them at high boost that they never do, then just tell everyone that they don't go any better without ever trying it themselves.
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
