got some cam gears for my 32 and i'm just checking that when installing them ready for tuning its best just to set them both to zero?
EDIT: I've just finished installing my adjustable cam gears and now the cars idle is extremely rough and eventually stalls, my ignition timing on my power fc is on about 20? Don't have a timing light so can't check it that way!
Anyone got any ideas what it could be? I made sure the harmonic balancer lines were at tdc aswell as having both the cam gears at 0 (figured i'd let my tuner play around with whats best)
PLEASE HELP!!!!
Edited by mr_rbman
https://www.sau.com.au/forums/topic/137751-installing-cam-gears/
Set them both to zero and dial them in on the dyno when you take it in for a tune.
If it's a 20, the inlet will most likely stay at zero and the exhaust will probably be changed to 2 degrees retarded but leave it up to the tuner to set it properly.
Definitely some tweaking to do ash.
Drop Andrew a line and see what he set his up at.
All though he was running RB20DET cams which run a 240duration 7.8mm lift exh cam vs the rb25de's 232duration 7.3mm.
I'll try to dig up the R32 RB25DE and RB20DET cam centerlines to get you started.
Ok got the centerlines...
R32 RB25DE
Inlet: 240dur 7.8mm lift, Centerline: 112degree's
Exh.: 232dur 7.3mm lift, Centerline: 118degree's (I think)
IVO: 8, IVC: 52, EVO: 54, EVO: -2
In/Exh lobe relationship (LCA): 115degree's
Overlap: 6degree's
RB20DET
Inlet: 240dur 7.8mm lift, Centerline: 115degree's
Exh.: 240dur 7.8mm lift, Centerline: 120degree's
IVO: 5, IVC: 55, EVO: 60, EVC: 0
In/Exh. labe relationship (LCA): 117.5degree's
Overlap: 5degree's
Should give you a good head start in where to begin fiddling. :ban:
Also note the tomei web site lists very very slightly(LCA) different specs for the cams. I'll believe the engine manual.
Where to start with the 3ltr... No idea :wave:
as said leave it at zero for the dyno operator to change...
on my rb20det i made more power everywhere with +3 inlet and -5 exhaust settings (do a search i wrote it all in a thread somewhere)
it basically shifted the power curve left so that at the same rpm i was making about 10% more power.. :(
it basically shifted the power curve left so that at the same rpm i was making about 10% more power.. :)
cheers, i tried looking for that thread as i remember it but i dunno what i do when i search but i never seem to find what i wanna look for!
Cubes, thanks for that but isn't that referring to camshafts rather than cam gears? I think i'll let Shaun just fiddle with it on the dyno, as long as i have it setup safe to drive for a while i'll be happy!
The cam gears is what setup the centerlines... For example 0 on the rb25de inlet cam is a centerline of 112degree's. Move the cam gear -5 or +5 and it changes the cams centerline accordingly.
So there's 3degree's difference between the std positioning of the rb25de and rb20det inlet cam.
Sky30 ran a heap of overlap to bring the turbo on sooner and pick up mid range power; from memory top end power was sacrificed by ~10rwkw but he picked up something like 20-30rwkw through the mid. He will be able to clear up the exact power increases. I can't remember exactly but those numbers do ring a bell. :)
Sky30 ran a heap of overlap to bring the turbo on sooner and pick up mid range power; from memory top end power was sacrificed by ~10rwkw but he picked up something like 20-30rwkw through the mid. He will be able to clear up the exact power increases. I can't remember exactly but those numbers do ring a bell. :P
ahhh, i understand now, takes me a couple of reads to understand things but i get there! I'll msg andrew!
3lit3,
By retarding the exh. cam by 2 degree's what sort of gains do you see? Mid to high rpm with no noticable loss from the low end?
Mainly just a jump in mid range. No loss down low but I am using a GT2876 with a 0.86 rear so it really has nothing down low anyway.
I'd say start again.
Rip out the radiator, harmonic balancer and cam belt covers.
Throw it on to TDC and check the cam timing is all lined up.
By leaving the harmonic balancer on and trying to line everything up its possible for the belt to be slightly off the lower drive gear (simply because there's no tension on it and you can't see it), as a result when you spin the motor over it jumps a tooth or two and the cam timing is thrown out.
If you remember back to when you first got the motor in the car, I checked and reset (as it was out a tooth) the cam timing; I pulled off the balancer as it wasn't worth the hassle of the lower drive gear being out a tooth or two.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
