Hi ppl
just recently i have noticed that if im in 2nd gear and i flat foot it, around 4-5k the car starts to backfire heaps..and also if im going like 100km and on 4th if i allow the car keep boosting, and change to 5th...generally i see flames out of the exhaust and soon after white smoke. I thought it might be the turbo thats blown and hence the white smoke, but ive tested the turbo and turbo seems to working fine.
as for mods, sitting on 9-10 psi using 32 actuator, fmic, zorst, no bov, everything is else standard.
i understand that the flame is due to fuel and white smoke - water..
but any clue as to why it would do this?
also i have just bought an ecu, so after a good tune i suppose this should go away?
cheers.
i still have the standard ecu at the moment. i hav bought a wolf 3d..havnt installed it yet, but will be in the coming weeks.
also i dont have a cat..straight 3" exhaust system, jus find it less restrictive than a hi flow system.
another mate did say it could be due to timing. and no i havnt checked base timing.
ok so the flames are due to not having the cat, but why the white smoke soon after? once it was pouring out..i had to wait a min and turn of the car, so it would stop. after i started the car it was gone.
the next day i checked all fluid levels. all was normal. so what could that have been?
cheers thanks for the past replies..really helpful :thumbsup:
Could be a spark related problem if its actually misfiring.
Good threads on that.
http://www.skylinesaustralia.com/forums/in...showtopic=51046
http://www.skylinesaustralia.com/forums/in...showtopic=32356
White smoke though, no idea.
Edited by Rolls
cheers thanks for that..
after reading the threads above..it sort of looks like i have a fair few cracks in the coil packs. I will suss that out tomorrow and tape it as some of the guys have done in the past as a temporary solution.
will keep posted.
Edited by SLYLNE
will keep posted.
i had the same problem in my 33 good old electrical tape worked wonders on the coils could boost it to 14psi
with no backfiring
just finished taping up the coils, running the standard 10psi without any misfiring.
since i couldnt locate any of these so called 'hair line' cracks..i decided to tape up all 6 and yes has worked wonders..red line on 1st - 2nd - 3rd..no misfiring at all, now im happy as larry.. lol
thanks to everyone that has helped me along with this problem and to everyone on the couple of threads linked above.
cheers :)
still anyone know why white smoke comes out immediately after a huge back fire?
is this just water? or something else?
since misfire problem has been solved, i have gone for a few hard runs and havnt heard backfire, flames or white smoke for that matter..just puff of black smoke durin the 1st run.
but would still like to know what the white smoke is? anyone..
cheers
Edited by SLYLNE
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
