Ok so i had a turbotech boost controller, and my boost was spyking, so i took it off to connect back my stock controller.
HOWEVER which way do the hoses go. Anyone got a pic, Does the hose from the turbo the inlet into the cooler go to the top or bottom of the selenoid. Where does the restrictor go, which way, to the wastgate or back to the gate.
I have run the car and it holds 10psi all the way to 5000rpm and then climbs up to 12-13psi.
The boost comes on strong as i have doen the grounging mod.
I just don't remember which way things go.
Looking at the diagram in the manual, the top goes to turbo inlet side before the cooler, then after the cooler, i pick up the one for the wastgate and the tee. Does the restrictor go after the tee on the wastegate side or before the tee on the intercooler side.
CAN SOMONE post pics.
ALSO if the boost goes up after 5000rpm why?
What could be the problems.
BTW. My car has all the supporting mods, dump, FMIC ect etc, hence the higher boost setting from stock.
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
