Can anyone help with pictures of their dry sump sump modifications. I am currently building a setup and have seen numerous setups but want to see an rb26 one that has been modified.
I have read the previous posts on dry sumps but no pics were posted.
https://www.sau.com.au/forums/topic/137799-dry-sump-setup-pics/
I have some pics of a Nismo GT500 engine from the last of the JGTC R34 GTRs that I took at nismo omori factory. They show the pump set-up and bracket, and some lines etc.
here you go you picture hungry animals. threw in a few nismo engine pics to make up for the slowness.
NISMO JGTC RB26 DRY SUMP SET-UP:
now that i see it's on a little dolly i should have wheeled it home :w00t:
lol, one day my son. one day.
There is so much to learn from that motor. I could stare at it for a fair while.
here's a couple more nismo motors:
NISMO S-TUNE MOTOR
NISMO NUR SPORT MOTOR
I think this one was an N-spec or production racing motor, definately some kind of race motor, but not as wild as the JGTC spec motor:
NISMO F-SPORT MOTOR (RB28):
NISMO R-TUNE MOTOR in it's natural habitat :O
And the grand daddy of street set-ups: The NISMO Z-TUNE MOTOR in it's natural habitat:
I'd have to say Nismo never fails to please.
*yes, they are all pics taken by me at Nismo, Omori, Japan.
So where is the oil , in a dry sump set up....I'am confused :)
Dam this mods.....
In a dry sump setup the oil is stored away from the block in a seperate reservoir. The oil cycles around the engine and back through the reservoir giving the oil to cool (whilst being away from the heat in the engine) before it re-enters the engine.
More here if you're interested: http://auto.howstuffworks.com/question331.htm
  • 3 years later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
